Re: Engine balance
[Re: Plymouth340]
#3110145
01/08/23 07:26 PM
01/08/23 07:26 PM
Posts: 4,206 New York
polyspheric
New York
Deepen the valve reliefs, create flame notches, shorten the skirts under the pins (non-thrust axis), but aluminum is 1/3 the weight of steel. In some cases, the piston pin can be taper-bored from both ends, go slow, keep it wet & cool.
Boffin Emeritus
Re: Engine balance
[Re: polyspheric]
#3110162
01/08/23 07:48 PM
01/08/23 07:48 PM
Posts: 1,986 Apollo, PA.
B1MAXX
Apollo, PA.
I would. under balanced is not the best way to be.
16 grams will be a tremendous task, especially on all 8. 16g's is a lot of aluminum.
I would first consider a different wrist pin. If it is chevy size, they make a lot of options.
Re: Engine balance
[Re: Plymouth340]
#3110470
01/09/23 11:10 PM
01/09/23 11:10 PM
Posts: 39 West Central Indiana
PROSTOCKTOM
Got new pistons for my small block. They weigh 16 grams each more than the old ones. Do I need to get the motor rebalanced?..8500 RPM On a 5000 rpm engine 16 grams matter. On a 8500 rpm engine 1 gram matters. Yes you need to rebalance.As previously mention taking 16 grams off the pistons might be tough to do. Changing the wrist pins is more probable, but you should still rebalance the engine. Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
