M1 vs Trickflow intake B-Block #3110002
01/08/23 10:22 AM
01/08/23 10:22 AM
sweden
carter Offline OP
carter  Offline OP
sweden
On a 512 cu with approximately 600hp can I see any gain to switch from a M1 S-P (4150) to a Trickflow intake? Is it wort the effort?
I shift at 5900 rpm.....
Thanks.
Re: M1 vs Trickflow intake B-Block [Re: carter] #3110074
01/08/23 02:30 PM
01/08/23 02:30 PM
AndyF Offline
AndyF  Offline
The Trickflow intake will make more power on the dyno than an M1 intake, but you'll have to decide if it is worth the money for your car. It is taller so you'll need hood clearance.
