Max wedge rods #3109744
01/07/23 01:20 PM
01/07/23 01:20 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Are 2406395 which are early maxie rods. Good rods to use for 426 max wedge.
Re: Max wedge rods [Re: mopar muscle7271] #3109758
01/07/23 01:43 PM
01/07/23 01:43 PM
West Central Indiana
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
Actually those are the second version of the 426 Wedge Rods which are a little heavier than the first version.
Here's a pictorial post on B-Bodies Only that shows both of the 426 and two other RB rods all side by side.
https://www.forbbodiesonly.com/moparforum/threads/rb-and-max-wedge-rod-pictorial-reference.175132/
Personally to me I've never had issues with any stock LY rod castings.
Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
Re: Max wedge rods [Re: mopar muscle7271] #3109872
01/07/23 07:23 PM
01/07/23 07:23 PM
As long as you have them magnaflux first and then have them blueprinted and replace the rod bolts and nuts with good ones like ARP before you use them twocents scope up
Re: Max wedge rods [Re: PROSTOCKTOM] #3109896
01/07/23 08:18 PM
01/07/23 08:18 PM
las vegas,nv
las vegas,nv
There the first version of max wedge rods it states in that link you sent
Re: Max wedge rods [Re: Cab_Burge] #3109963
01/08/23 01:12 AM
01/08/23 01:12 AM
las vegas,nv
las vegas,nv
I have a set of 426 max wedge pistons L2185 ones. Figure max wedge rods would be better then the ly rods.
Re: Max wedge rods [Re: mopar muscle7271] #3109969
01/08/23 01:35 AM
01/08/23 01:35 AM
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
Max Wedge rods are heavier, that doesn't necessarily mean they are better. Chrysler assumed that heavier was better and it caused a lot of race engine to blow up. You can only sling heavy rods and pistons around for so long before they explode.
A properly prepared LY rod will never let you down and weighs a lot less. Which is always a good thing in my world.
Tom
Re: Max wedge rods [Re: PROSTOCKTOM] #3109977
01/08/23 03:29 AM
01/08/23 03:29 AM
I remember seeing a lot of LY rods pull in two pieces in the middle from guys revving their 440 too high whiney, to hard and to long back in the late 1960s and early to mid 1970s whiney
OP, if you want to make your max wedge motor better buy a set of BB Chevy H or I beam rods with the 7/16 ARP 2000 bolts that are 7.100 long center to center and have your 440 rod journals offset ground to BB Chevy rod size, 2.200 and have the stroke increased to 3.91, have a set of pistons made, Icon has shelf stock pistons for that combination now I think.
That combination can make from 468 C.I. to 471 C.I. depending on what bore size you get, that combination works very well with max wedge heads, intake and carbs up scope
Can you say 550 HP on pump gas with 9.5 to 1 compression ratio grin devil up
Re: Max wedge rods [Re: Cab_Burge] #3109994
01/08/23 09:55 AM
01/08/23 09:55 AM
las vegas,nv
las vegas,nv
I plan on keepin everything mopar inside engine.im using max wedge rods with those max wedge pistons l have.dont have max wedge heads.may get a set of aluminum edelbrock heads.just have 906 or 516 heads may just rebuild to high performance specs.
Re: Max wedge rods [Re: mopar muscle7271] #3110052
01/08/23 01:23 PM
01/08/23 01:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might want to think about what the others have said, bigger = heavier which can lead to breaking usually mid-beam. In addition 60 year old rods may have been subjected to shruggy
I'll try to post an example of a 6 pak rod later beer
Re: Max wedge rods [Re: TJP] #3110228
01/09/23 12:13 AM
01/09/23 12:13 AM
las vegas,nv
las vegas,nv
Early max wedge rods are lighter then six pack rods are
Re: Max wedge rods [Re: mopar muscle7271] #3110270
01/09/23 09:20 AM
01/09/23 09:20 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That's not really saying much though.
Re: Max wedge rods [Re: mopar muscle7271] #3110317
01/09/23 12:10 PM
01/09/23 12:10 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Just a thought, but the block, rods, and pistons you have may be worth something to those looking for max wedge stuff. Might help fund a 440 build with better parts. Not trying to convince you of anything though.
Re: Max wedge rods [Re: TJP] #3110340
01/09/23 01:55 PM
01/09/23 01:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the motor actually srvived with a new rod and piston. He actually drove it home vibrating severely as the big end of the rod was still on the crank swinging around eek
Re: Max wedge rods [Re: TJP] #3110404
01/09/23 06:23 PM
01/09/23 06:23 PM
las vegas,nv
las vegas,nv
Wow that snap clean alright,still goin to use my pistons and rods l have.
Re: Max wedge rods [Re: TJP] #3110739
01/11/23 03:13 AM
01/11/23 03:13 AM
las vegas,nv
las vegas,nv
Early stage max wedge rods are still lighter then that six pack rod shown that snap.
Re: Max wedge rods [Re: mopar muscle7271] #3110746
01/11/23 07:42 AM
01/11/23 07:42 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
When is the last time those rods were made? If they weren't NOS I'd wonder where those rods spent the past 60 years.
Re: Max wedge rods [Re: Sniper] #3110994
01/11/23 10:26 PM
01/11/23 10:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The OP comes here asking a question and disputes all responses whistling rolleyes wave
Re: Max wedge rods [Re: TJP] #3111098
01/12/23 09:42 AM
01/12/23 09:42 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, well attention is needed I guess
Re: Max wedge rods [Re: TJP] #3111113
01/12/23 10:15 AM
01/12/23 10:15 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Well the question he asked sort of got answered and then in typical moparts fashion people told him what they would use instead ...
Me I'd use a set of aftermarket rods .... but he wants the inside of the engine , where no one will ever see what's in there till those 60 plus year old rods EXITS the side of the block , will never been seen ...
Re: Max wedge rods [Re: JohnRR] #3111325
01/12/23 07:33 PM
01/12/23 07:33 PM
las vegas,nv
las vegas,nv
If you have max wedge pistons like l have,use max wedge piston rods to. Max wedge pistons never had Ly rods on them.non heavier max wedge rods as stated above.has anyone used Ly rods on max wedge pistons? Seriously doubt anyone has.
