correct distributor for my 71 Super Track Pack #3107915
01/03/23 08:35 AM
01/03/23 08:35 AM
eastern L.I. ,NYC
K
kingdragon Offline OP
K
eastern L.I. ,NYC
Looking for expert advice on the probable distributor for my 71 Charger R/T w/ A36 with 4 barrel. Car is a super track pack automatic and I cant tell if it was original electronic or single points distributor. Is there particular holes on the firewall that I should look for that would give me a tell-tale that it had electronic control box? I dont have the build sheet and the original engine harness was chopped up for racing ignition. Its my understanding that the sixpack cars got a dual point system but I dont know if the 4barrel super track pack cars would've came with.
I'm eager to hear from you all. Thank you.
-KD
I only buy MADE IN USA.
Re: correct distributor for my 71 Super Track Pack [Re: kingdragon] #3107918
01/03/23 09:03 AM
01/03/23 09:03 AM
VA
dragon slayer Offline
VA
There is no dual point listed for 4B RB in the Prestolite books, only the 6 pack cars. The MOPAR parts manual should help, but I am thinking single point.
Re: correct distributor for my 71 Super Track Pack [Re: dragon slayer] #3107920
01/03/23 09:11 AM
01/03/23 09:11 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Single points.
For 71 the electronic ignition was an option on 340 cars. 72 was an option on all cars and 73 it was standard.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: correct distributor for my 71 Super Track Pack [Re: moparmarks] #3107962
01/03/23 11:12 AM
01/03/23 11:12 AM
eastern L.I. ,NYC
K
K
eastern L.I. ,NYC
Thanks for this. If I read you right 1971 440hp 4bbl had no option for electronic ignition.
Re: correct distributor for my 71 Super Track Pack [Re: kingdragon] #3107966
01/03/23 11:28 AM
01/03/23 11:28 AM
moparmarks Offline
moparmarks  Offline
Correct.
I fixed my typo.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: correct distributor for my 71 Super Track Pack [Re: moparmarks] #3107968
01/03/23 11:37 AM
01/03/23 11:37 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Originally Posted by moparmarks
Single points.
I believe 1972 first year for standard electronic ignition.
Ron
Re: correct distributor for my 71 Super Track Pack [Re: RJS] #3108209
01/03/23 05:47 PM
01/03/23 05:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Single points.
Ron
My father bought a 72 Duster twister , 318 , built in late nov/dec 1971 , it had points.
Re: correct distributor for my 71 Super Track Pack [Re: kingdragon] #3108243
01/03/23 06:52 PM
01/03/23 06:52 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 440 HP with Automatic
Distributor 3438694
Points
The distributor will have the electronic box retard feature attached to the vacuum advance
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: correct distributor for my 71 Super Track Pack [Re: bee1971] #3108473
01/04/23 03:21 PM
01/04/23 03:21 PM
moparx Offline
moparx  Offline
were the electronic retard canister on the distributor the same on B engines as the RB's ?
for some reason, i installed a distributor with the retard box on the 383 that is in my charger at the present time. it is a points distributor.
beer
Re: correct distributor for my 71 Super Track Pack [Re: JohnRR] #3108573
01/04/23 07:29 PM
01/04/23 07:29 PM
moparmarks Offline
moparmarks  Offline
Single points.
Ron
I have/had several 72's with points.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: correct distributor for my 71 Super Track Pack [Re: bee1971] #3108574
01/04/23 07:32 PM
01/04/23 07:32 PM
moparmarks Offline
moparmarks  Offline
Distributor 3438694
Points
Correct
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: correct distributor for my 71 Super Track Pack [Re: bee1971] #3111118
01/12/23 10:28 AM
01/12/23 10:28 AM
eastern L.I. ,NYC
K
K
eastern L.I. ,NYC
Thanks Bee71 this is great help. Can you explain what this electronic vacuum advance is/does please
Re: correct distributor for my 71 Super Track Pack [Re: kingdragon] #3111298
01/12/23 06:16 PM
01/12/23 06:16 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 - DISTRIBUTOR SOLENOID All 383 and 440 engines (except the 440 3-2V) have a solenoid incorporated in the distributor vacuum advance mechanism to retard the ignition timing when the throttle is closed. At closed throttle, electrical contacts on the carburetor throttle stop and with idle adjusting screw in the closed position, causes the dis- tributor solenoid to energize. This retards the ignition timing to provide reduced exhaust emissions under hot idle conditions. Cold or part throttle starting is not penalized because the distributor solenoid is not energized unless the hot idle adjusting screw is against the throttle stop contact. Timing must be set at closed
throttle to give ignition full retard.
Read all about it here
https://www.forbbodiesonly.com/moparforum/threads/vacuum-advance-w-solenoid.171617/
Siberian Huskies
