Oil Pressure at Start up
#310718
05/07/09 02:45 AM
05/07/09 02:45 AM
Posts: 6,295 U.S.
moparniac
U.S.
Just curious what everyones oil pressure is when first cranking over the motor.... Im sure it varies some but I have Indy heads with stock oiling 440 block and a solid roller. thx
Mopar Performance
Re: Oil Pressure at Start up
[Re: moparniac]
#310719
05/07/09 03:41 AM
05/07/09 03:41 AM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
You should ALWAYS pre-oil a new motor ...and anything that has been shut-down for any long period of time. You can DO SO ...with the new and improved PVC coated(to prevent bushing damage) aluminum or steel 5/16 hex rod. PM for details ! As far as what you will see with the starter spinning the motor over ? ...who knows ? ... lots of variables there.
[Re: dOoC]
#310720
05/07/09 03:46 AM
05/07/09 03:46 AM
Posts: 6,295 U.S.
moparniac
U.S.
Melling Hi Volume pump and its a 66lbs
Mopar Performance
[Re: moparniac]
#310729
05/07/09 11:22 AM
05/07/09 11:22 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
80 - 85 with our 572 440-1 Indy heads with Indy .040 restriction fittings, Milodon dual pickup 12 an hose to pump. 15-50 Kendall oil Oil pressure is immediate
[Re: Thumperdart]
#310731
05/07/09 02:04 PM
05/07/09 02:04 PM
Posts: 3,695 nc
emarine01
nc
I know a guy that swore you needed to crank the motor till you saw pressure then fire it up........his motor is now apart/broken. A motor can`t build much pressure cranking cos it`s spinning too slow but the minute it lights,pressure jumps right up.....
My engine makes 65psi on the starter,I crank for about 15 secs with 65psi then light it off, may be harder on the starter and batts but better than a dry start @ the crank, if I just light it off it is running in a half crank and It hits off hard and fast, the press comes up fast but its still takes a little time to oil everything?
[Re: emarine01]
#310732
05/07/09 02:08 PM
05/07/09 02:08 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I don't really see the benefit of cranking an engine with the ignition off to build oil pressure. Its still going to move around the same number of dry revolutions to build oil pressure. My use a preoiler if your concerned, or just start it. I don't see how 30 seconds of cranking to build pressure is any better then starting it for a second to build it.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: emarine01]
#310735
05/07/09 02:50 PM
05/07/09 02:50 PM
Quicktree
My theory is my race engine sits all week with out running so most of the oil film runs off , I only crank up oil press after the engine sits for a while not every time , There is also a difference in cranking compression load and firing load < rough guess 10 to 15 times > so the dry load on the bearing is higher with out cranking, a preoiler is a good thing , oil without any load but dont have one, I have read in some shop manuals for marine engines that sit for extended time to use the compression release or pull the spark plugs and crank to wet out the engine before starting, I know some do and some dont, But my point is that I dont think It is bad to crank up oil pressure with the starter unless some one here thoughts on why not to
do you do that with your daily driver? they set for weeks at times. doesn't dp much to spin it over first. but if it makes you happy do it.
[Re: Quicktree]
#310737
05/07/09 03:05 PM
05/07/09 03:05 PM
Posts: 3,695 nc
emarine01
nc
Hey Quik, my daily driver is a different thing, it rarely sits and I dont push it to its max every time I run it,I change my oil every 10 passes , thats 35 to 40 secs under load & I pull the pan every year on my race engine and check things my daily driver gets 3000mile oil and junked if its not up to the task
