Oil Pressure at Start up #310718
05/07/09 02:45 AM
05/07/09 02:45 AM
U.S.
moparniac Offline OP
U.S.
Just curious what everyones oil pressure is when first cranking over the motor.... Im sure it varies some but I have Indy heads with stock oiling 440 block and a solid roller.
thx
Mopar Performance
Re: Oil Pressure at Start up [Re: moparniac] #310719
05/07/09 03:41 AM
05/07/09 03:41 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
You should ALWAYS pre-oil a new motor ...and anything that has been shut-down for any long period of time.
You can DO SO ...with the new and improved PVC coated(to prevent bushing damage) aluminum or steel 5/16 hex rod.
PM for details !
As far as what you will see with the starter spinning the motor over ? ...who knows ? ... lots of variables there.
Re: Oil Pressure at Start up [Re: dOc !] #310720
05/07/09 03:46 AM
05/07/09 03:46 AM
U.S.
U.S.
Melling Hi Volume pump and its a 66lbs
Mopar Performance
Re: Oil Pressure at Start up [Re: moparniac] #310721
05/07/09 04:04 AM
05/07/09 04:04 AM
Florida STAYcation
Florida STAYcation
Is this running ...or the starter spinning it ? ... plugs in ??
Re: Oil Pressure at Start up [Re: dOc !] #310722
05/07/09 04:15 AM
05/07/09 04:15 AM
U.S.
U.S.
its running.....
Mopar Performance
Re: Oil Pressure at Start up [Re: moparniac] #310723
05/07/09 04:42 AM
05/07/09 04:42 AM
Florida STAYcation
Florida STAYcation
What weight oil ? ..... what rpm?
Re: Oil Pressure at Start up [Re: dOc !] #310724
05/07/09 04:51 AM
05/07/09 04:51 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
indy heads here & my engine jumps up to 75 psi on a cold motor at idle. when the oil is at peak temp after a run it's at 25 at idle.
Re: Oil Pressure at Start up [Re: rebel] #310725
05/07/09 07:52 AM
05/07/09 07:52 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My small block has 65 cranking , 65 cold idle @ 1200 rpm , 45-50 hot idle with a hv melling and 20/50 oil
Re: Oil Pressure at Start up [Re: moparniac] #310726
05/07/09 09:50 AM
05/07/09 09:50 AM
thx
I do not like cranking a motor over with the ignition off to get oil pressure before the mmotor starts I see, usually, around 75 to 80 lbs with cold oil on start up no matter what rpm it idles or revs to. 75 to 80 lbs is usually the bypass pressure it takes to open the bypass My big motor has had the bypass spring trimmed to reduce oil pressure to 65 to 68 lbs cold and it will idle at 17 to 22 lbs at idle with warm oil, above 150 F degrees with 5W20 weight oil
Re: Oil Pressure at Start up [Re: Cab_Burge] #310727
05/07/09 10:34 AM
05/07/09 10:34 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Cab , How come you dont like to crank to build press?
Re: Oil Pressure at Start up [Re: emarine01] #310728
05/07/09 11:05 AM
05/07/09 11:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know a guy that swore you needed to crank the motor till you saw pressure then fire it up........his motor is now apart/broken. A motor can`t build much pressure cranking cos it`s spinning too slow but the minute it lights,pressure jumps right up.....
Re: Oil Pressure at Start up [Re: moparniac] #310729
05/07/09 11:22 AM
05/07/09 11:22 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
80 - 85 with our 572 440-1 Indy heads with Indy .040 restriction fittings, Milodon dual pickup 12 an hose to pump.
15-50 Kendall oil
Oil pressure is immediate
Re: Oil Pressure at Start up [Re: Rodney] #310730
05/07/09 02:03 PM
05/07/09 02:03 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Not sure I buy into all the talk about wrecking your enigne by turning it over without it running.. I mean think about it, if you flood it or run the engine out of fuel with a mech fuel pump there are times you could crank the engine for a min or two with no fire. I've never heard of anyone wrecking an engine this way....
Just my
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Oil Pressure at Start up [Re: Thumperdart] #310731
05/07/09 02:04 PM
05/07/09 02:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My engine makes 65psi on the starter,I crank for about 15 secs with 65psi then light it off, may be harder on the starter and batts but better than a dry start @ the crank, if I just light it off it is running in a half crank and It hits off hard and fast, the press comes up fast but its still takes a little time to oil everything?
Re: Oil Pressure at Start up [Re: emarine01] #310732
05/07/09 02:08 PM
05/07/09 02:08 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I don't really see the benefit of cranking an engine with the ignition off to build oil pressure. Its still going to move around the same number of dry revolutions to build oil pressure. My use a preoiler if your concerned, or just start it. I don't see how 30 seconds of cranking to build pressure is any better then starting it for a second to build it.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Oil Pressure at Start up [Re: HemiDart68] #310733
05/07/09 02:24 PM
05/07/09 02:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the crank is never dry if it has been run recently. there is always a film o oil on the bearings.
Re: Oil Pressure at Start up [Re: HemiDart68] #310734
05/07/09 02:48 PM
05/07/09 02:48 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My theory is my race engine sits all week with out running so most of the oil film runs off , I only crank up oil press after the engine sits for a while not every time , There is also a difference in cranking compression load and firing load < rough guess 10 to 15 times > so the dry load on the bearing is higher with out cranking, a preoiler is a good thing , oil without any load but dont have one, I have read in some shop manuals for marine engines that sit for extended time to use the compression release or pull the spark plugs and crank to wet out the engine before starting, I know some do and some dont, But my point is that I dont think It is bad to crank up oil pressure with the starter unless some one here thoughts on why not to
Re: Oil Pressure at Start up [Re: emarine01] #310735
05/07/09 02:50 PM
05/07/09 02:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do you do that with your daily driver? they set for weeks at times. doesn't dp much to spin it over first. but if it makes you happy do it.
Re: Oil Pressure at Start up [Re: dOc !] #310736
05/07/09 02:53 PM
05/07/09 02:53 PM
U.S.
U.S.
Indy head 20w50 at idle...
Mopar Performance
Re: Oil Pressure at Start up [Re: Quicktree] #310737
05/07/09 03:05 PM
05/07/09 03:05 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Quik, my daily driver is a different thing, it rarely sits and I dont push it to its max every time I run it,I change my oil every 10 passes , thats 35 to 40 secs under load & I pull the pan every year on my race engine and check things my daily driver gets 3000mile oil and junked if its not up to the task
