Spark plug cross reference #3107296
01/01/23 06:09 PM
01/01/23 06:09 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
I am having trouble finding plugs for my 340. Looking for Champion N9Y or equal. It seems N9y’s are no longer available. I get a whole lot of possibilities (even within the same brand) when I try to cross reference them but have no idea what is correct. Any advice on a correct plug will be appreciated.
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107301
01/01/23 06:22 PM
01/01/23 06:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks like they're no longer using the traditional #s.
Autozone.com shows the following (all in copper, though platinum & etc are available) :
Champion 404 & 415
Autolite 65
NGK 6578
Re: Spark plug cross reference [Re: topside] #3107302
01/01/23 06:30 PM
01/01/23 06:30 PM
Warrenton, VA
Warrenton, VA
Champion 404 & 415
Autolite 65
NGK 6578
Thanks for the info but I wonder what plugs are the guys with 340’s actually using?
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107325
01/01/23 07:51 PM
01/01/23 07:51 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
NGK GR5
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107326
01/01/23 07:55 PM
01/01/23 07:55 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Champion Copper Plus Spark Plug 415 / RN9YC plugs are available from Amazon. Same heat range, but are resistor plugs to cut radio interference. $12.50 for a pack if four.
amazon.com/Champion-Copper-Plus-Spark-RN9YC
Re: Spark plug cross reference [Re: John Brown] #3107345
01/01/23 09:15 PM
01/01/23 09:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
RRJD - street 340 I used N9Y or N9YC - racecar 340 used C61YC...
Re: Spark plug cross reference [Re: John Brown] #3107350
01/01/23 09:52 PM
01/01/23 09:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
RN9YC are resistor plugs,
N9YC are not, the new Champion number is 300
https://www.championautoparts.com/find-my-part/Part-Number-Results.html?part=N9YC
https://www.rockauto.com/en/moreinfo.php?pk=317920&jsn=267
Re: Spark plug cross reference [Re: Sniper] #3107374
01/01/23 11:15 PM
01/01/23 11:15 PM
Warrenton, VA
Warrenton, VA
Thanks everyone. I’m going to look for the Champions
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107406
01/02/23 02:34 AM
01/02/23 02:34 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The old numbers are not used in the auto parts now. Except for Autolite and AC. NGK and Champions have part numbers that the counter guy needs to cross to so he can find the plug on the shelf. The minimum wage part timers may not know how to get your RN12YCs that are actually 404s. And the software is based on year, make and model. Asking for a BPR6ES without that information may get the "duh-duh" look.
Some of the old plugs, 55-51 Autolites and some on the non resistor numbers are no more. Race plugs are usually what you need for copper non-resistors..
Factory catalogs or websites will be helpful with numbers and what is still available. Have the part numbers when you go to the store.
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107407
01/02/23 02:43 AM
01/02/23 02:43 AM
Take a look at the Autolite 3911 and the colder 3910 non resistor race plugs scope
They work well for drag racing up to 7800 RPM, so far work
Re: Spark plug cross reference [Re: RoadRunnerJD] #3107412
01/02/23 05:31 AM
01/02/23 05:31 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
Thanks for the info but I wonder what plugs are the guys with 340’s actually using? [/quote]
Autolite 63 on my 340 runs great
Re: Spark plug cross reference [Re: solarguy] #3107417
01/02/23 07:12 AM
01/02/23 07:12 AM
md
mopars4ever Offline
mopars4ever  Offline
md
https://www.ebay.com/itm/115659614490 If not I`m pretty sure I have some boxes of old stock 64 autolites and some NOS 3420755 62 p plugs and some mopar N12y plugs.
Re: Spark plug cross reference [Re: mopars4ever] #3107428
01/02/23 08:59 AM
01/02/23 08:59 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your doing a lot of street driving a n9y is pretty cold. i'd suggest an n11y for street use. i like autolite 3924's for street driving but they're a little warm for highway driving.
Re: Spark plug cross reference [Re: lewtot184] #3107438
01/02/23 09:40 AM
01/02/23 09:40 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Great. First oil, then tranny fluid, then gear oil, now spark plugs.
Re: Spark plug cross reference [Re: solarguy] #3107718
01/02/23 03:13 PM
01/02/23 03:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Autolite 63 on my 340 runs great [/quote]
65 is the OE replacement. As the number get smaller, they get colder. We ran 55-51 back in the day. Same plug, nonresistor. Many of these numbers are NA. 63, 64 and 65 are still good.
Re: Spark plug cross reference [Re: CMcAllister] #3107733
01/02/23 04:18 PM
01/02/23 04:18 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
51 is now 315
53 is now 300
54 is now 302
55 is now 38
You can punch the old numbers in the link below and it will tell you the new number
https://www.championautoparts.com/find-my-part.html
