Shiming Valves Springs with flat washers #3107263
01/01/23 04:10 PM
01/01/23 04:10 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
If you were using a hardened cups under the springs and installing your shims under the cup, does the shim have to be hardened? I am having to shim over .200 so I was curious if I could sandwich a 1/2" flat washer under the cup and maybe sandwiched between two hardened shims so spring_cup_hardened shim_flat washer_hardened shim_head.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Shiming Valves Springs with flat washers [Re: clovis] #3107266
01/01/23 04:19 PM
01/01/23 04:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would hand this job off to your local engine machine shop.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Shiming Valves Springs with flat washers [Re: clovis] #3107267
01/01/23 04:20 PM
01/01/23 04:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Do you need .200" or .500"? If it were me and I needed .200" shim under the springs, I'd be looking for another spring.
Re: Shiming Valves Springs with flat washers [Re: justinp61] #3107275
01/01/23 04:39 PM
01/01/23 04:39 PM
birdtracker Offline
birdtracker  Offline
my OCD would not let me do that, I would be looking for a better spring choice. Birdtracker
Re: Shiming Valves Springs with flat washers [Re: clovis] #3107277
01/01/23 04:54 PM
01/01/23 04:54 PM
Are you feeling really lucky whistling
Anything rubbing against anything made of spring steel better be a s hard as the rubbing part is work scope
I use a lot of valve spring shims when setting up heads for solid roller lifter motors, some are spring steel and some aren't whiney I try and make sure the spring bottoms are sitting on a spring steel shim up wrench
Most of the .015 valve spring shims are black and made of spring steel up scope
Re: Shiming Valves Springs with flat washers [Re: Cab_Burge] #3107330
01/01/23 08:24 PM
01/01/23 08:24 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
My old 906's were about 1.88 ish valve height, the RPM's I'm setting up are right at 2.0 valve height. In checking all my springs (Isky 8005a), they are averaging about 380 lbs/in instead of 400 so I need a little bump there. The cups are .060 so I am having to shim anywhere from .140 to .170 to get 150 lbs on the seat and get them to within .100 of coil bind. I did learn on my first valve spring set up, not to the put a thin shim under the spring, hardened or not, as it beat them to death. I now put my shims under the cups and let the springs sit in the cup. I was able to find grade 8 washers at TSC, which I think are hardened for less than $5. I took my caliper with me, and was able to get 16 that all measured .100. I will sit the washer on the head, then my shim, then my cup.
'75 Plymouth Duster
Re: Shiming Valves Springs with flat washers [Re: clovis] #3107371
01/01/23 10:55 PM
01/01/23 10:55 PM
ake sure the springs are centering at either the top or bottoms so they can't walk around very much when revved up scope wrench up
Re: Shiming Valves Springs with flat washers [Re: clovis] #3107990
01/03/23 01:14 PM
01/03/23 01:14 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Might want to consider the Flatness of those washers....
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Shiming Valves Springs with flat washers [Re: W.I.N. Racing] #3108017
01/03/23 02:33 PM
01/03/23 02:33 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
What kind of variation would be acceptable? I did catch myself rubbing them on some sandpaper on my granite top just to knock down any high spots on on the coating. I noticed when I was comparing the grade 3 stuff to the grade 8, there was a lot less variation in thickness and appearance. It wouldn't take long to check the run-out on them. Worse case scenario is I hit with a surface grinder.
'75 Plymouth Duster
Re: Shiming Valves Springs with flat washers [Re: clovis] #3108367
01/04/23 09:38 AM
01/04/23 09:38 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I think the issue is that the valves want to rotate as they go up and down. Most valve spring shims have a up and a down side. The down side has small ridges to keep the shim from turning. I have taken a lot of cheaper shims off that were just hard steel, and you can see the wear marks where they spun on the head. A lot of stock engines especially truck engines have valve rotators so the valve spins freely, it helps keep carbon off the seats and promotes cooling of the valve. Got to remember valves have to cool with heat transfer to the seat and guide.
Re: Shiming Valves Springs with flat washers [Re: jwb123] #3108401
01/04/23 12:18 PM
01/04/23 12:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Are you saying .200" plus the locator? Sounds like the wrong spring/retainer/ lock for the aplication. Definately wouldn't use flat washers. -.100 retainers and -.050" locks would get you close.
Doug
Re: Shiming Valves Springs with flat washers [Re: dvw] #3110281
01/09/23 10:05 AM
01/09/23 10:05 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
The valve heights range from 1.965 to 1.9375, and I need an install height around 1.800 to get 150 on the seat, so I need around .190 to .220 of shim including the locator. I measure every spring to know exactly what height I need for each spring to hit 150, then I match my spring height to the valve height to limit the amount of shim for each valve. The grade 8 washers are hardened, and actually pretty flat, I measured several and got less than .0005 run out. I have cups with the ridges on the bottom and I have some that do not. I noticed the ones on the heads (aluminum) do not have the ridges and are smooth. I did search for a different spring one day, and I wasn't able to readily find a spring with 150 on the seat at 1.900 or so and still get within .100 of coil bind at around .560-.580 lift. Most of the ones I found where .150 or better on coil bind.
'75 Plymouth Duster
