727 bellhousing mystery**UPDATE: PICS added**
#3107143
01/01/23 06:32 AM
01/01/23 06:32 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
A friend of mine sent me these pics, he was trying to mate this 727 to his 5.2 Magnum engine. First pic is the 904 that was in the truck originally and it bolts to the 5.2 no problem. Second pic is of the 727 he wanted to swap in it. It looks like a SB bellhousing but compare the bolt hole and dowel pin location above the starter. What's up with that? He picked the 727 up as a core years ago so he doesn't know what it came out of. Has anyone else ever run into this?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 727 bellhousing mystery
[Re: fastmark]
#3107149
01/01/23 07:15 AM
01/01/23 07:15 AM
Guitar Jones
I'll see if I can get that.
[Re: Guitar Jones]
#3107160
01/01/23 10:01 AM
01/01/23 10:01 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Maybe it was behind an AMC motor.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3107178
01/01/23 11:06 AM
01/01/23 11:06 AM
Guitar Jones
I thought about that too, but have no idea what an AMC bellhousing pattern looks like.
[Re: 440_Offroader]
#3107271
01/01/23 04:33 PM
01/01/23 04:33 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The difference between the poly and the LA is the slight difference in the spacing of the bolt hole above the starter. It's a poly.
[Re: A727Tflite]
#3107290
01/01/23 05:49 PM
01/01/23 05:49 PM
Guitar Jones
Chrysler made transmissions for International Harvester, TUG airport equipment , AMC, others.
Need the case number from the Chicken Tender. He said he said he will check on it tomorrow.
[Re: Rhinodart]
#3107292
01/01/23 05:55 PM
01/01/23 05:55 PM
Guitar Jones
bolt pattern is big block. As said above, the PK number would tell you without question... I know big blocks have 4, 1/4" threaded bolt holes at the bottom for an inspection cover. This one has 3 , 1/4" holes and the two 7/16" holes for the support straps like a small block. Kunkel may be correct, I never looked at a poly engine bellhousing that I can remember.
[Re: John_Kunkel]
#3107294
01/01/23 05:59 PM
01/01/23 05:59 PM
Guitar Jones
The difference between the poly and the LA is the slight difference in the spacing of the bolt hole above the starter. It's a poly. is that the same for every poly engine or was there a build date change? Seems like this would come up more often.
[Re: Guitar Jones]
#3107298
01/01/23 06:18 PM
01/01/23 06:18 PM
John_Kunkel
Rio Linda, CA
I've only seen the SB bolt hole difference in the early 727 cases '62-?
[Re: John_Kunkel]
#3107328
01/01/23 08:03 PM
01/01/23 08:03 PM
Guitar Jones
