Hemi piston and rod assembly #3105879
12/27/22 11:10 AM
12/27/22 11:10 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Looks like the piston to rod assembly will be straight forward. Holding the piston with the intake valve notch away from you, hang the rod on it with the chamfer side to your left. They can all be assembled this way. Is this your technique?
Re: Hemi piston and rod assembly [Re: mopar dave] #3105945
12/27/22 03:47 PM
12/27/22 03:47 PM
Intake notch on the piston toward the cam and the rod bearing tangs in the rods towards the oil pan rails up
Re: Hemi piston and rod assembly [Re: mopar dave] #3105955
12/27/22 04:12 PM
12/27/22 04:12 PM
A727Tflite Offline
A727Tflite  Offline
You are correct. Back in the day the tangs were aimed to the outside because that meant the rod bearing oil squirters were then aimed toward the opposite bank and at the cam.
Not many bearings have squirters anymore. The chamfer is always supposed to be aimed at the undercut or radius fillet.
Re: Hemi piston and rod assembly [Re: A727Tflite] #3105982
12/27/22 07:57 PM
12/27/22 07:57 PM
Mt Morris Michigan
Mt Morris Michigan
Gonna try to finish up the short block this week. Thanks
Re: Hemi piston and rod assembly [Re: mopar dave] #3105983
12/27/22 08:08 PM
12/27/22 08:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Is it done yet ?
Pics man
Re: Hemi piston and rod assembly [Re: FastmOp] #3106023
12/27/22 10:10 PM
12/27/22 10:10 PM
Mt Morris Michigan
Mt Morris Michigan
This project will not be finished for a long time. Should be in the car about 3yrs from now.
