ignition switch tumbler replacement
#3105733
12/26/22 04:42 PM
12/26/22 04:42 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Can someone give me instructions on how to replace the ignition switch tumbler in a '68 B body?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: ignition switch tumbler replacement
[Re: 68LAR]
#3105742
12/26/22 05:01 PM
12/26/22 05:01 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
You can pop the lid off and drop out the tumblers if they are giving you trouble. With wear they can get sticky. Will start with any key or screwdriver.
I want my fair share
[Re: SomeCarGuy]
#3105754
12/26/22 05:37 PM
12/26/22 05:37 PM
68LAR
South Park, Pa.
You can pop the lid off and drop out the tumblers if they are giving you trouble. With wear they can get sticky. Will start with any key or screwdriver. . Iām replacing the switch. I want to keep my tumbler.
[Re: 68LAR]
#3105759
12/26/22 05:53 PM
12/26/22 05:53 PM
Posts: 4,748 Star Idaho
67vertman
Star Idaho
Before you can remove the bezel the tumbler must be removed...put the ignition switch in the accessory position, insert the paper clip through the small hole in the face of the tumbler depressing the spring loaded lock pin & twist the ignition further counterclockwise than it normally will go.. Then pull out on the tumbler... Now you can remove the bezel as previously mentioned it is easier with the correct tool, but can be done with a screwdriver, just be careful or you can damage the bezel. The rest is straight forward!
My Monster are real!
Living within your means makes life pretty easy.
[Re: GMP440]
#3105770
12/26/22 07:04 PM
12/26/22 07:04 PM
Posts: 6,246 nowhere
Sniper
nowhere
Where can tumblers be bought?
Depends on the make and model but Roackauto lists them for my 51 Plymouth. spot checked a later A body, out of stock.
[Re: GMP440]
#3105806
12/26/22 10:09 PM
12/26/22 10:09 PM
67vertman
Star Idaho
Last one I bought at NAPA.....https://www.napaonline.com/en/p/ECHKS6482?impressionRank=2
[Re: 67vertman]
#3105811
12/26/22 10:21 PM
12/26/22 10:21 PM
68LAR
South Park, Pa.
Before you can remove the bezel the tumbler must be removed...put the ignition switch in the accessory position, insert the paper clip through the small hole in the face of the tumbler depressing the spring loaded lock pin & twist the ignition further counterclockwise than it normally will go.. Then pull out on the tumbler... Now you can remove the bezel as previously mentioned it is easier with the correct tool, but can be done with a screwdriver, just be careful or you can damage the bezel. The rest is straight forward! I don't see a small hole in the tumbler. The bezel you are talking about is the one on the tumbler right? Not the surround nut that holds the complete switch in the dash, correct? From what I've read, anything after '68 is different than '68 and older. In other words, anything '69 and newer are different.
[Re: 68LAR]
#3105818
12/26/22 10:32 PM
12/26/22 10:32 PM
Sniper
nowhere
For a 68 the hole is in the side of the ignition switch not the bezel. Here's a ic of the tumbler, you can see the brass button that needs to be pushed in https://www.rockauto.com/en/moreinfo.php?pk=1186423&cc=1081820&pt=10041&jsn=446Here's the switch, you can see the rectangular hole in the threaded portion that allows access to the button in the tumbler. You will have to disconnect the wiring connector and unscrew the nut to pull the switch first. https://www.rockauto.com/en/moreinfo.php?pk=44023&cc=1081820&pt=4700&jsn=463
[Re: Sniper]
#3105835
12/27/22 12:24 AM
12/27/22 12:24 AM
68LAR
South Park, Pa.
For a 68 the hole is in the side of the ignition switch not the bezel. Here's a ic of the tumbler, you can see the brass button that needs to be pushed in https://www.rockauto.com/en/moreinfo.php?pk=1186423&cc=1081820&pt=10041&jsn=446Here's the switch, you can see the rectangular hole in the threaded portion that allows access to the button in the tumbler. You will have to disconnect the wiring connector and unscrew the nut to pull the switch first. https://www.rockauto.com/en/moreinfo.php?pk=44023&cc=1081820&pt=4700&jsn=463 . Got it. Thanks!š. That what I needed to know.
[Re: Sniper]
#3105901
12/27/22 12:21 PM
12/27/22 12:21 PM
67vertman
Star Idaho
For a 68 the hole is in the side of the ignition switch not the bezel. Here's a ic of the tumbler, you can see the brass button that needs to be pushed in https://www.rockauto.com/en/moreinfo.php?pk=1186423&cc=1081820&pt=10041&jsn=446Here's the switch, you can see the rectangular hole in the threaded portion that allows access to the button in the tumbler. You will have to disconnect the wiring connector and unscrew the nut to pull the switch first. https://www.rockauto.com/en/moreinfo.php?pk=44023&cc=1081820&pt=4700&jsn=463 Thanks Sniper!
