Can you lengthen a driveshaft? #3105058
12/23/22 09:44 PM
12/23/22 09:44 PM
BDW Offline OP
BDW  Offline OP
Curious if lengthening a driveshaft is possible?
After my Gen3 swap, engine moved forward, so the yoke engagement is less.
Wasn't optimal before the swap, but now it's even less, probably ~1.5" back from bottoming out.
Wondered what detrimental affect the less yoke engagement might cause?
Re: Can you lengthen a driveshaft? [Re: BDW] #3105060
12/23/22 10:02 PM
12/23/22 10:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
How much engagement do you still have?
The place I use doesn't necessarily lengthen them, but will use your ends and put a new tube in.
Re: Can you lengthen a driveshaft? [Re: slantzilla] #3105352
12/24/22 11:07 PM
12/24/22 11:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Three things,
#1 as mentioned above (spline engagemnt)
#2 Overall length of the yoke and output bushing placement
#3 If in doubt get it lengthened.
how you drive the car & how much power come into play as do tires and others as well, #3 is Much cheaper that the potential damage it can cause /cost
twocents beer
Re: Can you lengthen a driveshaft? [Re: TJP] #3105378
12/25/22 08:33 AM
12/25/22 08:33 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
With the small amount you're talking, it is likely a non-issue, but anytime you lengthen a driveshaft you reduce the critical speed and you can get into issues with driveline harmonics. The critical speed depends on the length, the diameter, and the material.
Re: Can you lengthen a driveshaft? [Re: BDW] #3105384
12/25/22 09:48 AM
12/25/22 09:48 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't think my local shop will lengthen one. It could be done I'm sure, but I wouldn't.
Re: Can you lengthen a driveshaft? [Re: justinp61] #3105396
12/25/22 10:39 AM
12/25/22 10:39 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
They just take your ends off of the existing tube, put in a longer tube and reweld and balance. Not a big deal. Take it to any truck shop that makes driveshafts. Now unless you have 1000 hp, I would get someone else to make it.
Re: Can you lengthen a driveshaft? [Re: Dodgeguy101] #3105428
12/25/22 12:54 PM
12/25/22 12:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
None of those places have the ability to balance at the speeds needed for a race/performance app.
Been there, done that. Was like riding a paint shaker. One race old. It came out and went in the scrap pile. But not before beating up the good yoke and tailshaft.
Few years ago had one done for a customer car. Pretty mild combo. Visible runout.
Driveshafts are no joke.Use a shop that does race shafts. Send them the yoke, if it's a good piece, give them a C-C and pay them. Sleep better.
Re: Can you lengthen a driveshaft? [Re: Dodgeguy101] #3105432
12/25/22 01:03 PM
12/25/22 01:03 PM
BDW Offline OP
BDW  Offline OP
Anyone have a measurement on the length of splined part on the transmission side?
I'm going to take some measurements to calculate the engagement.
Need to know how deep on the trans side has splines.
Interesting to see the first 1.75" on the yoke side is not splined?
That seems to indicate the amount of contact isn't critical?
Why would they leave that much length/area with no contact/overlap?
Re: Can you lengthen a driveshaft? [Re: CMcAllister] #3105463
12/25/22 02:31 PM
12/25/22 02:31 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Well, all I can say is the place that did mine did a very good job of balancing it. I guess your results will vary with anything.
Re: Can you lengthen a driveshaft? [Re: Dodgeguy101] #3105506
12/25/22 05:07 PM
12/25/22 05:07 PM
moparx Offline
moparx  Offline
i'm wondering if not having the yolk splined for the first inch or so, is to allow ease of assembly. in other words, the unsplined section allows the yolk to be supported on the tailshaft, while the assembler then has it easier to rotate the shaft to engage the tailshaft and yolk splines.
however, the tailshaft only has a certain length of splines on it, so [in my opinion] the yolk must [or should] have the female spline length that would be completely engaged with the male spline length on the tailshaft during all suspension movements and articulations.
i also agree about getting the shaft trued and balanced for high speed operation, not for truck use. this is especially true if one has an overdrive transmission and deep rear gears.
beer
Re: Can you lengthen a driveshaft? [Re: moparx] #3105509
12/25/22 05:26 PM
12/25/22 05:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The smooth area at the front of the splines was to accommodate a seal on the output shaft (seen on right in pic below) that was used for the first years of the slip yoke.
Re: Can you lengthen a driveshaft? [Re: John_Kunkel] #3105520
12/25/22 06:36 PM
12/25/22 06:36 PM
BDW Offline OP
BDW  Offline OP
Thx for the pic, would it be possible to get a measurement of how long that splined section is?
My guess would be only 3"
Re: Can you lengthen a driveshaft? [Re: Dodgeguy101] #3105528
12/25/22 07:59 PM
12/25/22 07:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes, retubing is a common deal. Not what I thought of when I see "lengthening a drive shaft.
Re: Can you lengthen a driveshaft? [Re: CMcAllister] #3105529
12/25/22 08:06 PM
12/25/22 08:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I installed the S-60 in my Dart I had a driveshaft built by a very highly recommended shop in Michigan. After the install the car had a vibration, I played with pinion angles, rebalanced tires, rechecked the driveline angles, nothing helped. Finally, I had the transmission out for a converter change and called my local driveshaft shop to have the balance checked. It was waaaaaaaaaay out! He rebalanced it and it's smooth as silk even at 135 mph.
BTW, the shop in Michigan charged almost $500 for a "race" driveshaft, snake oil.
Re: Can you lengthen a driveshaft? [Re: justinp61] #3105681
12/26/22 01:36 PM
12/26/22 01:36 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
It can be done, I watched my auto shop teacher lengthen a driveshaft 2" back in the 80's using some pipe and lathe.
The equipment that the modern driveshaft shops have now is so good and quick, I'm not sure that a backyard fix is worth the time though in messing around.
Re: Can you lengthen a driveshaft? [Re: BDW] #3105683
12/26/22 01:47 PM
12/26/22 01:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the splines on the shaft are 3" long. On a typical 727 factory slip yoke, the bore is 6 1/2" deep and the un-splined area is 1 1/2" deep, so there are 5" of splines internally.
Re: Can you lengthen a driveshaft? [Re: John_Kunkel] #3105747
12/26/22 05:10 PM
12/26/22 05:10 PM
BDW Offline OP
BDW  Offline OP
Appreciate the info/confirmation.
My 95 518 yoke bore is 7" deep.
Last piece of the puzzle is how much of that 3" on the trans side protrudes beyond the end of the tailshaft.
Hope to get my trans back this week, will measure then
Re: Can you lengthen a driveshaft? [Re: John_Kunkel] #3105886
12/27/22 11:39 AM
12/27/22 11:39 AM
moparx Offline
moparx  Offline
i learned something here. thanks John. up
beer
Re: Can you lengthen a driveshaft? [Re: moparx] #3106018
12/27/22 09:48 PM
12/27/22 09:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just note that those slip yoke that used the seal JK mentions have a vent hole on the end.
Re: Can you lengthen a driveshaft? [Re: BDW] #3106063
12/28/22 05:29 AM
12/28/22 05:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sure, but I doubt it would be worth it, and even if welded straight and true, the welds could be a stress point as the tube twists. Likely cheaper (labor wise) to just have a new tube of the correct length welded to the yokes.
