Weird RAM issue #3104036
12/20/22 06:34 PM
12/20/22 06:34 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
2004 Ram . The LAMP OUT light is on in the dash. all lights work except RR turn sig . When the right turn sig is applied , the relay clicks real fast , and the rear sig doesnt work . Front sig works .
Its NOT the ts bulb , ive tried 3 . and the weird part is this = with the whole tail light assembly removed and unplugged , I tested voltage at the plug from the truck harness.
It should flash from 0 to 12v or so consistently yes ?? It just sits there at a solid 8V on the ts terminal. Any ideas ??
Re: Weird RAM issue [Re: 493_DART] #3104079
12/20/22 08:34 PM
12/20/22 08:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You are correct, it should be 12 volts, off and on. Where are you picking up the ground for your test meter, through the tail light ground? Could be just a bad ground for the right side tail light assembly (everything at the taillight uses the same ground wire). The turn/brake has the most voltage and a bad ground often shows up as the voltage increases.
After the ground check, if it was mine, I would be following the wiring between the two sets of tail lights. Next if you have a trailer light connection, I would start there. Generally, the wiring comes from the front on the driver side and crosses over to the right side near the rear bed crossmember, but it often branches over to the trailer connecter on the way to the right side. If the trailer connection is good, I'd be looking for a frayed or badly corroded wire for the turn signal power to the right taillight.
Re: Weird RAM issue [Re: poorboy] #3104085
12/20/22 08:48 PM
12/20/22 08:48 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Good idea -- ill check at the trailer plug . As far as ground I was probing ground pin in the plug...the rest of the lights there work fine so im doubting that ground is bad
Re: Weird RAM issue [Re: 493_DART] #3104096
12/20/22 09:18 PM
12/20/22 09:18 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I'ts the board that the bulbs are plugged into,common problem,might be able to clean the prongs where bulb is plugged it.
Re: Weird RAM issue [Re: GarageDodge] #3104305
12/21/22 06:18 PM
12/21/22 06:18 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
nope...the whole light assembly isnt plugged in.
Re: Weird RAM issue [Re: 493_DART] #3104317
12/21/22 06:45 PM
12/21/22 06:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Fuse box on those years is notorious for wierd issues with lights, turn signals, etc
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Weird RAM issue [Re: GarageDodge] #3104324
12/21/22 08:02 PM
12/21/22 08:02 PM
5thAve Offline
5thAve  Offline
That's what it was on my 2004 with the same problem. New board was only like $20. I'm not sure sure how it works to know there's a burnt out bulb but that could be why it's seeing 8V. Did you try pulling apart the other side to see what it does?
Re: Weird RAM issue [Re: 5thAve] #3104346
12/21/22 09:23 PM
12/21/22 09:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Like this.
Re: Weird RAM issue [Re: B3422W5] #3104347
12/21/22 09:26 PM
12/21/22 09:26 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Funny you mention that...i was just reading about the TIPM (fusebox) . I guess it can cause all kinds of weirdness,,,my truck has been acting strange here and there........like trying to stall , wipers turn on by themselves ...now the turn signal
Re: Weird RAM issue [Re: 493_DART] #3104348
12/21/22 09:31 PM
12/21/22 09:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
All stuff you mention are things I have seen with the box.
If you swap it out..make sure it is from the same year truck, there are differences between years generally.
Bet a dime to a doughnut you have a fuse box corrosion issue. Extremely common. Hopefully you can find a good used one.
https://repairpal.com/tipm-issues-138
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Weird RAM issue [Re: B3422W5] #3104381
12/21/22 10:59 PM
12/21/22 10:59 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I went through HELL on the TIPM, lost the right trailer light, then would lose the BUS occasionally between the cab and the engine compartment, then other lights started being intermittent. I finally got a rebuilt TIPM because no factory one's are available, got it off eBay.
JB Rhinehart, Realist
A-Body's RULE!
Re: Weird RAM issue [Re: 493_DART] #3104425
12/22/22 02:52 AM
12/22/22 02:52 AM
I would post this in the truck section twocents
Re: Weird RAM issue [Re: Cab_Burge] #3104436
12/22/22 08:21 AM
12/22/22 08:21 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No need now, OP should have a handle on it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Weird RAM issue [Re: B3422W5] #3104637
12/22/22 05:53 PM
12/22/22 05:53 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Guess what happened last night ? Wipers are completely dead now . Im going to try the hard reset of the Tipm....cant afford a new or rebuilt one . Awesome !! And i cant go do the reset because its -936 degrees out . More awesome.
Re: Weird RAM issue [Re: 493_DART] #3104650
12/22/22 06:39 PM
12/22/22 06:39 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
With the loss of wipers i would say tipm is corroded inside,it will keep geting worse,good luck.
Re: Weird RAM issue [Re: GarageDodge] #3104670
12/22/22 07:48 PM
12/22/22 07:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Bunch on E bay for 200 bucks or less.
They aren’t that expensive
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Weird RAM issue [Re: B3422W5] #3104738
12/22/22 11:08 PM
12/22/22 11:08 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Is the TIPM just the metal module on the side of the fusebox? Or do you have to replace the entire thing ?
Re: Weird RAM issue [Re: 493_DART] #3104756
12/23/22 12:16 AM
12/23/22 12:16 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Complete fuse box
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Weird RAM issue [Re: B3422W5] #3105319
12/24/22 07:53 PM
12/24/22 07:53 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
To anyone that has done the hard reset ....does it matter if the tipm is still plugged in when connecting the batt cables together ?
Re: Weird RAM issue [Re: 493_DART] #3105328
12/24/22 08:31 PM
12/24/22 08:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Reset isn’t going to fix it
1.41 best 60 foot
6.60 at 103.90 1/8
