Re: Trans mount help [Re: 360view] #3102403
12/14/22 09:44 PM
12/14/22 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by 360view
Originally Posted by fastmark
Well. I may try another attempt to modify this mount. I just put too much ͏H͏e͏at at one time. I knew better. This new mount is not even wide enough to fill up the space like the old old either.
Many users have bragged about making custom vibration isolators from Sugru moldable silicone
https://sugru.com/what-is-sugru
a challenge is how to test a custom height mount prior to road use
their website says it will hold 600 times it's weight or 4.4 lbs whistling not sure if that increases with more product. Some complaints on AMZ about the quantity in the packages being less than a grab and go ketchup pack shruggy beer
Re: Trans mount help [Re: 360view] #3102469
12/15/22 07:50 AM
12/15/22 07:50 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well, we got in a poly mount from Amazon and it’s only a little high. I think we can work with it. We may have to slot the holes more. I used 3/8” bolts in the early cross member so I would not have to slot the holes so much. Looks like a bigger problem is the tail shaft is not quite centered in th tunnel. This is a hemi with Arruza mounts a so it could be off a tick. It would not have to be off much to move it over some. The GV tailshft has a reinforcement ridge that may need a little trimming. Thanks for the help.
Re: Trans mount help [Re: fastmark] #3102525
12/15/22 12:08 PM
12/15/22 12:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the update wink What brand of Poly mount ? maybe helpful for others beer
Re: Trans mount help [Re: TJP] #3102598
12/15/22 04:17 PM
12/15/22 04:17 PM
moparx Offline
moparx  Offline
also, what was the height of the mount ?
beer
Re: Trans mount help [Re: moparx] #3102768
12/16/22 06:32 AM
12/16/22 06:32 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I think it’s an Energy suspension and it’s 3.25 high. He put it in but I’ll final tweet it today that may help. I’ll post a picture. 3” would have been perfect.
Re: Trans mount help [Re: TJP] #3103612
12/19/22 03:02 PM
12/19/22 03:02 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Originally Posted by TJP
how does one REBUILD a vulcanized Trans mount? Especially one that looks USED? whistling rolleyes
I have poured mounts for my Geo, like
https://www.energysuspensionparts.com/diymmi
but a different brand.
Cut most of the old out, and/or burn remaining out with a torch. New will bond fine.
Re: Trans mount help [Re: Ray S] #3103772
12/19/22 10:43 PM
12/19/22 10:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Was not aware they offered it up beer
Re: Trans mount help [Re: TJP] #3103831
12/20/22 09:00 AM
12/20/22 09:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Same way they made them to begin with.
https://www.then-now-auto.com/plymouth-motor-mounts/
Re: Trans mount help [Re: Sniper] #3103892
12/20/22 12:20 PM
12/20/22 12:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Trans mount help [Re: TJP] #3103903
12/20/22 12:45 PM
12/20/22 12:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've modified cross memebers to use this style chevy mount. Had one in my race car for 11 years. The bolt spread is a little off but the welder and a couple of thick washers fixed that.
https://www.summitracing.com/parts/...mptKI_AIVpBPUAR2mMg8PEAQYBCABEgLw1vD_BwE
Also check energy suspension. GM mounts have either 3 3/4" or 4 1/4" bolt spacing. Some have slotted mounting holes.
https://teamenergysuspension.com/en...-transmission-mounts/transmission-mounts
Doug
