right/left magnum rockers same-same?
#3102959
12/16/22 07:26 PM
12/16/22 07:26 PM
Posts: 250 Falcon, CO
Mad-Max
Falcon, CO
need someone to check my brain - my rebuild book naturally doesn't say and the interwebs are a bit lax on the subject, but magnum rockers are same-same from intake to exhaust? - IOW they appear to be interchangeable, there's no respective right and left (intake/exhaust), ja? And when re-using used ones...so long as the oil groove and corresponding 'tattoo' on the rocker match up yer good to go, ja? Doesn't matter if the oil groove is an innie or an outie just as long as they match during reassembly? Much grass, - Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
Re: right/left magnum rockers same-same?
[Re: RTSrunner]
#3103060
12/17/22 11:10 AM
12/17/22 11:10 AM
Mad-Max
Falcon, CO
my kind of logic - thanks
