removal of ThermoTec suppressor mat #3102333
12/14/22 04:57 PM
12/14/22 04:57 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I need to remove some of the ThermoTec sticky backed mat from the floor pan of my Challenger to weld in some subframe connectors. What have you guys done to successfully remove it?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: removal of ThermoTec suppressor mat [Re: randavis] #3102366
12/14/22 07:26 PM
12/14/22 07:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Good luck with that !!
Re: removal of ThermoTec suppressor mat [Re: randavis] #3102395
12/14/22 09:20 PM
12/14/22 09:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Only way I know of is elbow grease. IE: heat gun, scrapers followed up with solvents. Might try calling Thermo Tec and asking them wink
Reminds me of a customer many years ago. Short version wink He had completely taken his 69 Chevelle down to the bare frame. He had the frame sandblasted but could not find anyone to paint it. Being paranoid about it rusting he had it completely undercoated. He wanted up to finish the car.
It was the tar based cr-p and was still gooey. I told him it has to be stripped. He asked how much? I said 1k Minimum + materials.
He thought that was too much. So I said, you go buy some tarps to catch the goo and I'll let you strip the majority of it off in the gravel area below. Once you have the majority of it stripped I'll finish it off with my steam cleaner. for 200 + supplies.
I did find that easy off worked pretty well and passed that info onto him. About 14 man hours later, a sh-t pot full of easy off, several pairs of gloves and about 7 tarps, he was done ( in more ways than one LOL).
He commented it would've been the best 1k he had spent in quite some time. I should also mention it was August, hot & humid but he was at least in the shade wink
if you do call thermoTec post back with their suggestion beer
Re: removal of ThermoTec suppressor mat [Re: TJP] #3102528
12/15/22 12:14 PM
12/15/22 12:14 PM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
I got a response from them after I emailed them yesterday.
Thank you for contacting us about your Suppressor Mat.
First, I will say there is no good way to remove this.
I would suggest trying to heat the mat to soften the adhesive and pull it up, using a putty knife or blade to help remove the adhesive.
It will be a very sticky mess. Once you get the mat removed you can use a good solvent to help remove the remaining adhesive.
Let us know if you have any other questions.
Good luck!!
Re: removal of ThermoTec suppressor mat [Re: randavis] #3102600
12/15/22 04:24 PM
12/15/22 04:24 PM
moparx Offline
moparx  Offline
whatever you do, don't use brake clean solvent to clean the area you are welding on.
when it gets heated, the solvent [even though it states it leaves no residue] creates phosgene gas, and if you get a big whiff of that, you won't be able to tell us how your project turned out.
look up "mustard gas". not very good stuff to be around.
beer
Re: removal of ThermoTec suppressor mat [Re: randavis] #3102642
12/15/22 06:33 PM
12/15/22 06:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Get a small amount of dry ice and lay it on a corner and see what happens.
Re: removal of ThermoTec suppressor mat [Re: A12] #3102715
12/15/22 10:00 PM
12/15/22 10:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might be worth a shot, Different materials but it just might work. shruggy To the OP keep us posted either way wink beer
Re: removal of ThermoTec suppressor mat [Re: moparx] #3102737
12/15/22 10:59 PM
12/15/22 10:59 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
beer
Thanks for this info. I had no idea that this was a serious issue. We use Kleen Flo 313 cleaner for all our parts cleaning!!!!.. I looked up the Safety data Sheet and it contains 70-80 % Tetrachloroethylene. When you heat this chemical > 315C creates phosgene gas!!!!! Deadly stuff!! Be very careful!!
https://www.envirofluid.com/articles/tetrachloroethylene-a-deadly-danger-in-brake-cleaner/#:~:text=Heating%20Tetrachloroethylene%20brake%20cleaner%20residue,presence%20of%20welding%2C%20creates%20Phosgene
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: removal of ThermoTec suppressor mat [Re: A12] #3102781
12/16/22 08:56 AM
12/16/22 08:56 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Halt!
It is forbidden.
You are not permitted to find useful aspects of any form of
EVIL carbon dioxide,
be it gas, liquid or solid.
Take it from an “addicted” sinner.
You do not want to learn how to
clearance fit tight metal parts,
blast clean corrosion without gritty leftovers,
or heaven forbid - remove warts.
Learn from the Stromatolites,
never mix DNA, sunlight and carbon dioxide.
The seas of a whole planet turned from
beautiful Green
to evil Blue
smile
Re: removal of ThermoTec suppressor mat [Re: RealWing] #3102860
12/16/22 01:41 PM
12/16/22 01:41 PM
moparx Offline
moparx  Offline
beer
very bad stuff indeed.
i don't know where i first learned about this, but i think it may have been when MSDS books were mandated in industry during my machinist career.
long ago, we used to clean the grease off our hands with tricloroethelene. that stuff worked great. then we found out it was a carcinogen, absorbed through the skin ! eek
well, THAT practice stopped in a heartbeat........
beer
Re: removal of ThermoTec suppressor mat [Re: randavis] #3103065
12/17/22 11:35 AM
12/17/22 11:35 AM
Missouri
randavis Offline OP
randavis  Offline OP
Missouri
UPDATE:
Yesterday, I removed the interior of the car. I found that I had used two different sound deadening products. The area that needs to be removed is covered with Cool It Insulating Mat. This is the resin-bonded silica blanketing insulation sandwiched between a mylar facing on one side and a foil facing on the other. I used contact cement to adhere it to the floor. I believe that acetone or lacquer thinner will remove it easily.
I used the sticky stuff on the curved areas because it conforms to it a lot better than the mat.
I had forgot that I had used both products. (CRS of a 70 year old).
I would still be interested in hearing if the dry ice would work on the sticky backed stuff. As an aside, I used some of Eastwood's sticky stuff, also, and it seems to have a lower melting point than the ThermoTec.
Re: removal of ThermoTec suppressor mat [Re: randavis] #3103113
12/17/22 02:31 PM
12/17/22 02:31 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
dry ice works amazingly well. i had a customer bring me a supra that had been stripped of seam seal that way and it was shocking how well it worked.
Re: removal of ThermoTec suppressor mat [Re: randavis] #3103203
12/17/22 10:37 PM
12/17/22 10:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by randavis
UPDATE:
Lucky you beer
