Re: Will Repro Group 27 Batteries Ever Be Made Again
[Re: mopars4ever]
#3116891
01/26/23 11:23 PM
01/26/23 11:23 PM
Posts: 203 Alabama
David1971
Alabama
Yes it does. I removed the 6 caps. Looking down into the case, it appears to be an Odyssey AGM battery.
David
[Re: mopars4ever]
#3117203
01/28/23 12:58 AM
01/28/23 12:58 AM
Posts: 203 Alabama
David1971
Alabama
I intended to call Jim's today to ask for the manufacturer and model of the AGM, but forgot. I will call next week. Here is the info that came with the battery:
[Re: David1971]
#3117208
01/28/23 01:41 AM
01/28/23 01:41 AM
Posts: 567 WA
tman
WA
I intended to call Jim's today to ask for the manufacturer and model of the AGM, but forgot. I will call next week. Here is the info that came with the battery: When you do call, do ask is there a way to open the case when the battery dies so we can replace ourselves. Thx
[Re: tman]
#3117247
01/28/23 11:02 AM
01/28/23 11:02 AM
Posts: 203 Alabama
David1971
Alabama
I intended to call Jim's today to ask for the manufacturer and model of the AGM, but forgot. I will call next week. Here is the info that came with the battery: When you do call, do ask is there a way to open the case when the battery dies so we can replace ourselves. Thx I too was curious if that could be done. When I asked last year, this is the response I got: "Very difficult and very time consuming. But it can be done." Here is a picture of the underside. You can see a seam near the outer edge,,, that's where I would probably began the surgery if I needed to get inside the case.
[Re: DynoDave]
#3117641
01/30/23 02:25 AM
01/30/23 02:25 AM
Posts: 203 Alabama
David1971
Alabama
Good news on the caps and decals...good news on the resto case with AGM inside.
What does that new Jim's battery weigh? It's not visible in the image I uploaded of the shipping carton...but the UPS Ground shipping label states 35 lbs.
[Re: mopars4ever]
#3118222
02/02/23 02:55 AM
02/02/23 02:55 AM
Posts: 203 Alabama
David1971
Alabama
Did Jims give you any info on it? What warranty did they give with the battery? I wonder about the cranking amps on that particular battery? I spoke to Jim yesterday and asked for the name of the manufacturer and model of the battery inside. He said it was an Odyssey and the model was "similar" to a PC925. I then asked if the specs were exactly the same as the PC925. His response was "very close". My last question was if the battery was custom made for him. He said no.
[Re: David1971]
#3118254
02/02/23 10:35 AM
02/02/23 10:35 AM
Posts: 302 Hinckley, Ohio
KWF340
Hinckley, Ohio
I intended to call Jim's today to ask for the manufacturer and model of the AGM, but forgot. I will call next week. Here is the info that came with the battery: When you do call, do ask is there a way to open the case when the battery dies so we can replace ourselves. Thx I too was curious if that could be done. When I asked last year, this is the response I got: "Very difficult and very time consuming. But it can be done." Here is a picture of the underside. You can see a seam near the outer edge,,, that's where I would probably began the surgery if I needed to get inside the case. I've done this - it's not that bad. Just cut along the edge/seam and make sure you leave enough to accept a screw to hold a new plexi cover (to keep the new battery in the case). The hardest part is getting the replacement cable the right length so it can be tightened to the new battery terminal and still fit within the case. The replacement battery was a PC925. Link
1968 Charger R/T, 440, Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1966 Corvette convertible, L79, 4-speed, Red 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: tman]
#3118505
02/03/23 08:06 AM
02/03/23 08:06 AM
KWF340
Hinckley, Ohio
Battery we are referring to are from "Jims Battery" cases with a battery inside. So when it fails, we are trying to figure out an easy way to change it out the inner battery. I assume all the hardware to hook them up are inside. So this would be a no mess situation like the one you are referring to. I totally agree, cleaning out an exiting battery is a mess and lots of work. The hardware is there, but you will find the cables are too short. Best to get a longer cable and cut to size. There isn't much room in the case to fit your hand in there and make the connection to the battery.
[Re: KWF340]
#3118571
02/03/23 11:56 AM
02/03/23 11:56 AM
Posts: 4,632 Motor City
6PKRTSE
Motor City
I bought 12" cables and do my conversions with the Odyssey PC925 batteries.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparx]
#3118630
02/03/23 03:27 PM
02/03/23 03:27 PM
Posts: 21,910 Kirkland, Washington
Pacnorthcuda
what does the pc925 battery weigh ? 23.8 pounds. I put one in my gutted retro case. I weighed the old batt before gutting and the damn thing was 58 pounds. I think my odyssey version is 28-29.
[Re: mopars4ever]
#3118729
02/03/23 09:58 PM
02/03/23 09:58 PM
6PKRTSE
Motor City
Actually, it rolls over my 10.75:1 440 faster than the reproduction batteries ever did.
