help me understand instant center as applies to leaf springs #3101593
12/12/22 01:56 PM
12/12/22 01:56 PM
pa
gregcharger72 Offline OP
pa
I am converting my cars rear suspension to a cal-trac setup.with the mono leaf springs and QA 1 double adjustable shocks.What I am replacing a set of launcher springs that i've had on the car for several years. The car is a 72 charger weighs 3500lbs and runs mid 10's @ 126 mph. with a best 60ft of 1.47. I foot brake the car ,no trans brake.
My dilemma is the front spring hanger has two mounting holes. As a starting point i am not sure which mounting position to use. Does it even make a difference?
The current set up with the launcher springs uses the upper mounting hole . One of the reasons I'm switching to the cal-tracs is the car hits the tire so hard that I'm having trouble controlling the seperation and I'm about maxed out on my rebound adjustment with the shocks . Ultimately what I'm after is a quicker reaction time from the car and an improved 60ft time.
So what would be your recommendation or advice as to a starting point.
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101606
12/12/22 02:23 PM
12/12/22 02:23 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
upper hole raises the instant center. Your real problem is the short front segment of a Mopar leaf spring, and your real solution is a shock that can control the movement of the rear housing. GET A GOOD SHOCK or get what you have re valved if possible. There are a few places that will help you with a good stiff shock for the back of a leaf spring mopar. You will be surprised at just how stiff a shock it takes to control the seperation
....BAD A$$ STREET CAR.....
Re: help me understand instant center as applies to leaf springs [Re: n20mstr] #3101619
12/12/22 03:19 PM
12/12/22 03:19 PM
UK
rb446 Offline
rb446  Offline
UK
My mate has mono's -c-tracs in the upper hole on his RR, motor has 720ftlbs on the hit and is controlled by just caltrac 9-way shocks on 7 stiff, good DA shocks are important yes, wait till you get those mono springs onto see the difference, here's a vid of the car on a 10.35 hit, been a best 1.421 60ft.@3800lbs>
https://www.youtube.com/watch?v=9tnu9cSnf2U
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: help me understand instant center as applies to leaf springs [Re: n20mstr] #3101622
12/12/22 03:28 PM
12/12/22 03:28 PM
pa
pa
so you are saying that the front spring mounting position does not matter in reducing or incresing the hit to the tire? Only a GOOD shock will control it?
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101623
12/12/22 03:28 PM
12/12/22 03:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The current set up with the launcher springs uses the upper mounting hole . One of the reasons I'm switching to the cal-tracs is the car hits the tire so hard that I'm. having trouble controlling the seperation and I'm about maxed out on my rebound adjustment with the shocks . Ultimately what I'm after is a quicker reaction time from the car and an improved 60ft time.
Don't make the rear suspension less aggressive. Buy better shocks and control it.
Talk to AFCO or Randy at Fastshocks. You will be flabbergasted at what good shocks will do for your car.
And work on the front end. Skinny T-bars, free it all up at the control arms and strut bushings, good shocks there as well.
Stock Eliminator people have been working on this stuff forever. Copy them
Do all that, then start tuning.
Re: help me understand instant center as applies to leaf springs [Re: CMcAllister] #3101624
12/12/22 03:34 PM
12/12/22 03:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Instant center location determines housing movement direction. The higher or further rearward the instant center, the more it will seperate. Housing seperation adds hit to the tire. The shock controls the speed at which the housing moves.
Doug
Re: help me understand instant center as applies to leaf springs [Re: dvw] #3101626
12/12/22 03:38 PM
12/12/22 03:38 PM
pa
pa
Doug
This is helpful. thanks.
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101636
12/12/22 04:07 PM
12/12/22 04:07 PM
N
n20mstr Offline
n20mstr  Offline
N
lowering the IC or lowering the front of the leaf spring might reduce the seperation, but surely not enough that a great shock isnt needed. You will find its all about controling the movement of the rear housing.
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101637
12/12/22 04:11 PM
12/12/22 04:11 PM
N
n20mstr Offline
n20mstr  Offline
N
YES you are close to maxxed out on the rebound adjustment.....this is what im talking about. YES the caltracs are great, but they wont work on their own. Whatever suspension you use, you still need a good shock.
What shocks do you have?? If they are a good, name brand, its possible they could be re valved to allow more stiffer rebound, thats control you need...
Re: help me understand instant center as applies to leaf springs [Re: n20mstr] #3101640
12/12/22 04:35 PM
12/12/22 04:35 PM
pa
pa
ok that makes sense, thanks. I'm using QA1 stocker star double adj. I looked into santhuff shocks....wow are they expensive!
Does a mid 10 sec car really need a shock like santhuffs? what are other good shock choices?
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101642
12/12/22 05:02 PM
12/12/22 05:02 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Viking make a good affordable shock .Thats what i have on the rear .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101644
12/12/22 05:15 PM
12/12/22 05:15 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Get them now if you can, you won't have to buy anything else later when you run out of adjustment or struggle with the cheaper shocks unless you go to struts or a 4 link (DAMHIK)
I'm only running mid 9's but they made a world of difference on mine. We went 1.41 on the rears with a 3.73 gear @ 4000 lbs + on our last pass of the season.
We previously ran Menscer valved Afco's, the Santhuffs are a vastly superior piece.
Re: help me understand instant center as applies to leaf springs [Re: tex013] #3101647
12/12/22 05:17 PM
12/12/22 05:17 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If your shocks are in the stock location you might try moving them so they can be more straight up. My car runs 10.40s but it hits the tire real hard and my DA vikings are maxed out. I am going to stand them up before I upgrade.
68 Barracuda Formula S 340
Re: help me understand instant center as applies to leaf springs [Re: Bad340fish] #3101658
12/12/22 05:48 PM
12/12/22 05:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
This worked well for us. We built an upper bracket to move the top of the shocks closer to the frame rail and get them almost vertical. Even the Calvert shocks needed/liked this and it was easy to do.
'63 Dodge 330
11.19 @ 121 mph
Re: help me understand instant center as applies to leaf springs [Re: GY3] #3101668
12/12/22 06:09 PM
12/12/22 06:09 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
The GTX in the picture went 1.31 60 ft on Calvert bars, mono springs and 9 way single adjustable at 3550LBS. I switched over to ladder bars and coil overs. They did improve consistency, but the car has only equaled the the same 60ft times since the change.
Always mounted my bar in the lowest hole with little to no preload.
Re: help me understand instant center as applies to leaf springs [Re: rb446] #3101674
12/12/22 06:34 PM
12/12/22 06:34 PM
pa
pa
I just watched the video, the car looks very well controlled on the launch. That is what I'm after.
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101684
12/12/22 07:11 PM
12/12/22 07:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
Have you looked into switching to ladder bars with coil overs? If not I think you should twocents
The reason I'm suggesting this is I use to race against John Calvert in NHRA stock when he was developing the Cal Tracks, he would have used ladder bars if they had been legal, I would have also up
Look into a set of 36 inch long ladder bars and real good set of double adjustable coil over with 6.0 inches plus travel and go have fun getting your back and neck hurt from the G force on the leave devil
AKA, a 1.42 60 ft. times can hurt you if you're leaning forward on the leave, especially if you're a big guy that doesn't work out your upper body frequently whiney shruggy
A 1.23 60 ft. time can and will make you grin a bunch boogie wrench
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101685
12/12/22 07:11 PM
12/12/22 07:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
60 ft is also a function of power to the tire. Be it gear ratio, converter, or plain old engine power. If the chassis doesn't have excessive movement and the car hooks consistantly. The 60 ft is about what it is. Some cars need chassis seperation and pitch rotation to hook. Some don't. A lot of variables in the equation. What kind of track prep? weight distribution? A 10.50 car will generally be in the mid 1.4x 60ft range. I doubt you need Santuffs in your ET range. Are they good? Heck ya. But they're pricey. I personally run Afco's. Resonably priced. With proper valving they work well. I can't comment on Vikings as I haven't used them. Many seem to be happy with them.
Doug
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101696
12/12/22 07:40 PM
12/12/22 07:40 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I will second the info on the cal trac setups mentioned. But jut to stimulate some thinking, the main force that is planting the tire is through the front spring eye, the cal trac s keep the spring from deforming so it transfers the power. But some energy is also applied by the back of the spring pulling down on the car. So don't overlook the need for proper shackles and sufficient travel for the spring to go through the arc of motion as the body separates.
Re: help me understand instant center as applies to leaf springs [Re: gregcharger72] #3101759
12/12/22 10:39 PM
12/12/22 10:39 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Do you mean body separation like this? Sorry about sideways pic.
America First!
