SURGING Six Pack carbs
#310136
05/06/09 05:15 PM
05/06/09 05:15 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
I've got a set of new six pack carbs from Mopar Performance.
While driving under normal circumstances they constantly surge and surge.... I've checked for vacuum leaks and set the outboards to make sure they're shut completly, but now I'm at a loss...
Any ideas? Suggestions?
CHECK OUT MY NEW WEB SITE !
Re: SURGING Six Pack carbs
[Re: anlauto]
#310137
05/06/09 05:25 PM
05/06/09 05:25 PM
RapidRobert
there have been some comprehensive threads on 6 pack tuning. You might see if it can be retrieved. bump up your center carb jets 4 sizes & try it.
[Re: Challenger 1]
#310139
05/06/09 06:33 PM
05/06/09 06:33 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Usally means lean.
yup. 1st thing I did w. my new set-up was drop some 64's in. Haven't driven it yet. trying to get the brakes set-up.
[Re: PHJ426]
#310143
05/26/14 01:04 AM
05/26/14 01:04 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Thank you, I have an earlier version from him but it is always a good read. It does not however mention anything about surging and even though it would not hurt them or me to go back to square one and tune them by his standards they seem to run great, I have had an occasional hot start issue but minor and it will occasionally try to load up at idle. So while I am typing I am talking myself into going through the set up process from Tom. Thanks for adding to my work load I have to leave in 12 days!
Careful, your character's showing!
[Re: mopar346]
#310145
05/26/14 04:07 AM
05/26/14 04:07 AM
Posts: 43,207 Bend,OR USA
Cab_Burge
I did a set of OEM 340 AAR Cuda carbs years ago, it was very sensitive to the center carb. jets, one size up or own made it not drive well I didn't look up the carb. # you posted, if it is a original, not a replacement carb with a -1 or -2 to the right of the list number then try looking on Holley web site for the original jetting and start with that, don't forget to use the proper power vave, especially with that dang Mopar 284 camshaft Good luck, I agree with the others on the surging, one step, one Holley # richer jet, not 4 should eliminate the surging Let us know what you do and the results please.
[Re: ThermoQuad]
#310147
05/26/14 10:50 AM
05/26/14 10:50 AM
mopar346
Thanks folks, I will make some changes over the next few days and post my results.
Tom, I have them saved to my computer and the above link takes you to it but thank you for your input.
[Re: ThermoQuad]
#310148
05/26/14 11:08 AM
05/26/14 11:08 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
thermostat 195
this right here is probably the single most overlooked and ignored step in the whole guide but it does make a difference....
[Re: mikemee1331]
#310149
05/26/14 12:58 PM
05/26/14 12:58 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
thermostat 195
what does it do.
[Re: ademon]
#310153
05/26/14 03:09 PM
05/26/14 03:09 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
thermostat 195
what does it do.
The 340 6 pack intake has an issue with fuel puddling. Colder the intake, the worse the issue.
[Re: ademon]
#310154
05/26/14 03:13 PM
05/26/14 03:13 PM
mikemee1331
bethlehem pa
thermostat 195
what does it do.
answered above! engine is hotter, fuel doesn't puddle
[Re: anlauto]
#310155
05/26/14 04:11 PM
05/26/14 04:11 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
before DOING ANYTHING unplug the vacuum advance... [plug hose] and drive to see if it cures it..
