Neutral Safety Switch
#310111
05/06/09 03:51 PM
05/06/09 03:51 PM
Posts: 25,945 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How many of you who run the TF in their track only car use the factory NSS and how many use the NSS in their aftermarket shifter?
Re: Neutral Safety Switch
[Re: WILD BILL]
#310118
05/06/09 07:15 PM
05/06/09 07:15 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am using the factory switch
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#310119
05/06/09 07:23 PM
05/06/09 07:23 PM
Posts: 34,939 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My shifter is PPP I use the furd solinoid mounted in the rear and had to find the correct one to work with the factory neutral switch
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#310120
05/06/09 08:35 PM
05/06/09 08:35 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Factory 3 wire switch. Only using middle wire.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Rodney]
#310121
05/06/09 08:39 PM
05/06/09 08:39 PM
I use the OEM unit with the switch that has one terminal / nut which the wire fastens to wire to starter relay done deal.
my 63 has the correct NSS with the white plastic internal and 1 wire and my 2 65's have the correct 65 metal inside with 1 wire stud as well.
[Re: John_Kunkel]
#310125
05/07/09 05:13 PM
05/07/09 05:13 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
3 prong here ,center for grounding starter switch outer 2 for activating trans brake for reverce
JAKES AUTOMOTIVE
