Re: Trans mount help
[Re: 360view]
#3102403
12/14/22 09:44 PM
12/14/22 09:44 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
Well. I may try another attempt to modify this mount. I just put too much ͏H͏e͏at at one time. I knew better. This new mount is not even wide enough to fill up the space like the old old either. Many users have bragged about making custom vibration isolators from Sugru moldable silicone https://sugru.com/what-is-sugrua challenge is how to test a custom height mount prior to road use their website says it will hold 600 times it's weight or 4.4 lbs not sure if that increases with more product. Some complaints on AMZ about the quantity in the packages being less than a grab and go ketchup pack
[Re: TJP]
#3103612
12/19/22 03:02 PM
12/19/22 03:02 PM
Posts: 157 PINE VALLEY
Ray S
PINE VALLEY
how does one REBUILD a vulcanized Trans mount? Especially one that looks USED? I have poured mounts for my Geo, like https://www.energysuspensionparts.com/diymmibut a different brand. Cut most of the old out, and/or burn remaining out with a torch. New will bond fine.
[Re: Ray S]
#3103772
12/19/22 10:43 PM
12/19/22 10:43 PM
TJP
Omaha Ne
how does one REBUILD a vulcanized Trans mount? Especially one that looks USED? I have poured mounts for my Geo, like https://www.energysuspensionparts.com/diymmibut a different brand. Cut most of the old out, and/or burn remaining out with a torch. New will bond fine. Was not aware they offered it
[Re: Sniper]
#3103892
12/20/22 12:20 PM
12/20/22 12:20 PM
TJP
Omaha Ne
