Best head gasket for TF 270's ? #3099794
12/05/22 12:56 PM
12/05/22 12:56 PM
Shannonville, Ont
Blown 68 R/T Offline OP
Shannonville, Ont
What's everyones go to head gasket for the 270's?
Putting together a RB 505 and use to run solid copper.
When i set the 4.380 gasket on the block it's fine but when i line it up on the head the gasket sits inside the chamber on some area's.
I mocked up a set of SCE copper 4.520's and Cometic C5464's (4.500) and they fit nice around the chambers.
Am i overthinking this or just run the bigger gaskets?
Re: Best head gasket for TF 270's ? [Re: Blown 68 R/T] #3099820
12/05/22 02:13 PM
12/05/22 02:13 PM
AndyF Online content
AndyF  Online Content
Use Cometic if they are available
Re: Best head gasket for TF 270's ? [Re: Blown 68 R/T] #3099847
12/05/22 03:34 PM
12/05/22 03:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My “go to” gasket bore diameter for stock 400/440 blocks is 4.410”.
However, I haven’t test fit one on a TF head myself....... although I have several customers with TF heads that have used them without issue.
Re: Best head gasket for TF 270's ? [Re: fast68plymouth] #3099870
12/05/22 04:28 PM
12/05/22 04:28 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have the Cometic 4.410's on mine . 0.030 over factory block , 0.055 over factory block and 0.030 World block .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Best head gasket for TF 270's ? [Re: Blown 68 R/T] #3099892
12/05/22 05:51 PM
12/05/22 05:51 PM
Is the block a stock Mopar or aftermarket block? Iron or aluminum?
Re: Best head gasket for TF 270's ? [Re: Cab_Burge] #3100007
12/06/22 01:20 AM
12/06/22 01:20 AM
Shannonville, Ont
Shannonville, Ont
Cab
It's a 75 440 block, 30 over
Re: Best head gasket for TF 270's ? [Re: tex013] #3100008
12/06/22 01:25 AM
12/06/22 01:25 AM
Shannonville, Ont
Shannonville, Ont
Tex have you ever checked to see if the gasket is hanging over in the chambers in certain area's?
Re: Best head gasket for TF 270's ? [Re: Blown 68 R/T] #3100024
12/06/22 05:19 AM
12/06/22 05:19 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I did a quick visual and seemed ok .Never noticed any sign of burn on gaskets when i swapped the heads between the 3 different motors .
Tex
New best MPH 130.32
Re: Best head gasket for TF 270's ? [Re: Blown 68 R/T] #3100063
12/06/22 11:03 AM
12/06/22 11:03 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have been using the Fel Pro marine head gasket with my Victor E heads on a 400 block. Never an issue.
Re: Best head gasket for TF 270's ? [Re: mopar dave] #3100404
12/07/22 01:21 PM
12/07/22 01:21 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
FWIW, that's a 4.500" bore gasket, regardless of what the specs say.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
