02 Dodge external voltage regulator diagram
#3100160
12/06/22 03:29 PM
12/06/22 03:29 PM
Posts: 249 Falcon, CO
Mad-Max
Falcon, CO
Can anyone confirm this diagram is correct for installing an external voltage regulator in an '02 Dodge (Dakota) using the OE alternator? PCM is long gone... Thanks, - Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
Re: 02 Dodge external voltage regulator diagram
[Re: NITROUSN]
#3100165
12/06/22 03:52 PM
12/06/22 03:52 PM
Mad-Max
Falcon, CO
Coolieo! Muchass Happygas
[Re: Mad-Max]
#3100206
12/06/22 07:28 PM
12/06/22 07:28 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Yep, stupid simple. Keep in mind the voltage regulator must be grounded.
[Re: Guitar Jones]
#3100354
12/07/22 11:13 AM
12/07/22 11:13 AM
Mad-Max
Falcon, CO
good - compared to the rest of this build I'll take as much 'stupid simple' I can get Copy 'grounds'
