Page 3 of 4 1 2 3 4
Re: Windage Trays...for big blocks [Re: Harry's Taxi 2] #3098622
12/01/22 10:43 AM
12/01/22 10:43 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Originally Posted by Harry's Taxi 2
I've used 2 of these.
https://bobmazzoliniracing.com/store/#!/Big-Block-Crank-Scraper/p/81474464/category=4301789
Cheap and "in stock". I wonder how much trimming it needs for a good fit... sawzall
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Windage Trays...for big blocks [Re: Brad_Haak] #3098733
12/01/22 06:28 PM
12/01/22 06:28 PM
PA
Harry's Taxi 2 Offline
PA
Needs a little trimming for a 4.15 crank. I trimmed it in the mill for a nicer finish.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Windage Trays...for big blocks [Re: Harry's Taxi 2] #3098752
12/01/22 07:26 PM
12/01/22 07:26 PM
Liny no worky whiney shruggy
Re: Windage Trays...for big blocks [Re: Cab_Burge] #3098756
12/01/22 07:32 PM
12/01/22 07:32 PM
PA
PA
i don't know how to make it a link. i just tried a copy and paste and that worked.
Re: Windage Trays...for big blocks [Re: Harry's Taxi 2] #3098761
12/01/22 07:40 PM
12/01/22 07:40 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The cut-outs leave sharp edges, which will eventually develop in cracks as the pan flexes.
Possible remedy:
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: Harry's Taxi 2] #3098801
12/01/22 10:23 PM
12/01/22 10:23 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
This link should work.
Scraper link
Re: Windage Trays...for big blocks [Re: GomangoCuda] #3098810
12/01/22 11:03 PM
12/01/22 11:03 PM
It did, thanks bow up
I should call him and jerk his chain a little to raise his blood pressure and make sure his heart is still beating whistling grin devil
We are both getting old whiney shruggy
Better than dying, huh work grin
Re: Windage Trays...for big blocks [Re: Cab_Burge] #3098863
12/02/22 08:38 AM
12/02/22 08:38 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
As one of my older bro's says, every day above ground is a good one
Re: Windage Trays...for big blocks [Re: Hot 340] #3098956
12/02/22 03:06 PM
12/02/22 03:06 PM
New York
polyspheric Offline
polyspheric  Offline
New York
My crude illustration (above) is also relevant to other physical shapes with sharp internal corners. Among these are modified K-members and crankshaft rod journals: if you can't obtain a radius as a safety, undercutting the intersection with a stop drill works very well.
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: polyspheric] #3098959
12/02/22 03:25 PM
12/02/22 03:25 PM
moparx Offline
moparx  Offline
basic machining 101...........radius all corners for strength.
beer
Re: Windage Trays...for big blocks [Re: moparx] #3099035
12/02/22 06:37 PM
12/02/22 06:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
But... to add a radius, the existing surfaces must both be cut back by the radius dimension. This ruins the scraper, and changes the rod bearing size.
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: polyspheric] #3099263
12/03/22 05:06 PM
12/03/22 05:06 PM
moparx Offline
moparx  Offline
hmmm........something i never thought of.
beer
Re: Windage Trays...for big blocks [Re: moparx] #3099298
12/03/22 07:19 PM
12/03/22 07:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
On cranks, they cut a radius into the cheek adjacent to the rod journal (not the journal) so no finished machined surface is disturbed.
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: Hot 340] #3099366
12/04/22 12:32 AM
12/04/22 12:32 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
After following this post and doing some research on windage including watching a couple vids from Engine Masters, I think my plan will be to get the Milodon 30931 pan with appropriate windage try for the 4.500 stroke and possibly a scraper. No fancy pans for me. If getting a scraper becomes to difficult than i simply wont use one. Thanks for posting because i had no plan of using a windage tray with this build before reading this post. Something else i learned with this windage research is there is as much HP to gain with scrapers and trays as there is with running less oil in the pan. Looks to me like some guys have too much oil in the pan.
Re: Windage Trays...for big blocks [Re: mopar dave] #3099396
12/04/22 08:38 AM
12/04/22 08:38 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
It's not the HP for me, that's a bonus, it's the dropping oil pressure in the shut down that gets me worried. I run a rudimentary scraper and wndage tray on a 4.50 stroke wedge, it still loses around 25 psi shutting down. I have to run a shallow pan, min level and also use an accumulator. We lose about 40psi with the 5.00 stroke wedge, no windage tray or scraper as we didn't have one to fit at the time. It's obviously aerating the oil, the bearings check out OK but I'd still rather it didn't do it at all.
Re: Windage Trays...for big blocks [Re: Tig] #3099401
12/04/22 09:02 AM
12/04/22 09:02 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Despite all the things I did to my pan, etc., I'm still waiting to find out if I have an issue w/ pressure loss after a full pass. If so, guess my next step is some form of oil accumulator to keep the system pressurized. work
Re: Windage Trays...for big blocks [Re: Tig] #3099410
12/04/22 10:07 AM
12/04/22 10:07 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would have to take a peak at my inside vids going down track, but as i remember i had about 55psi going down track and this is a 408, so 4.000 stroke. That would only be about a 5psi drop. It did not have a windage tray or scraper. My current 511with 4.250 stroke has a tray only and losses nothing going down track. It uses a milodon pump.
Re: Windage Trays...for big blocks [Re: mopar dave] #3099470
12/04/22 12:53 PM
12/04/22 12:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Keep in mind that windage trays and scrapers are two different things that do different jobs.
The scraper gets parasitic oil off the rotating assembly. That reduces weight and helps get the oil back to work. The portion of the scraper that is not scraping affects windage but in an unpredictable manner. There's still all kinds of buffeting and a hefty oil mist hurricane in the crankcase.
A windage tray is used to prevent that hurricane from frothing the oil in the pan. You need that bucket of oil down there to be on its best behavior. A relaxed pool is needed for more reliable pump pickup and steady pressure.
If winds are gusting to 60 mph you close the doors and windows, right?
Use the scraper to get oil off the spinny bits at high rpm.
Use the tray to relax the oil in the pan.
Use baffles to keep the oil near the pick up screen.
- Stu Harmon
Re: Windage Trays...for big blocks [Re: Hot 340] #3099515
12/04/22 02:44 PM
12/04/22 02:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A deep pan offers several advantages, of which the most obvious is more oil capacity.
It also allow the oil to rest farther below the crank's spinning bits, and increases the air volume above the oil level. This acts as a buffer against crankcase pressure spikes.
Boffin Emeritus
Re: Windage Trays...for big blocks [Re: polyspheric] #3099516
12/04/22 02:50 PM
12/04/22 02:50 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Tom Hoover used to say the in Chrysler Performance Clinics back in the day, that once you used a windage tray no horsepower improvements in the pan were effective.
All the engine saw was the windage tray.
If I recall correctly he thought there were still applications for them but the better the pan the less need for the tray.
At least this is they way I remember it but it was a long time ago.
Page 3 of 4 1 2 3 4
