Air compressor check valve question(s) #3097973
11/29/22 12:28 AM
11/29/22 12:28 AM
Between Houston & Galveston TX
SattyNoCar Offline OP
I've got a Brute 15 gal 125psi compressor I picked up for cheap almost 10 yrs ago. For my occasional use, it has served me well.
This past weekend, the check valve failed, as in, it came apart. The pressure regulator failed in a similar manner not long after I bought the unit (chinese high quality.....)
The exact replacement is no longer available (of course).
So my question is:
Are all check valves basically the same, meaning, can I use a 'universal' type one in its place?
(A new compressor is out of the question right now, and this unit otherwise works fine).
[Linked Image][Linked Image][Linked Image]
Thanks! beer
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3097989
11/29/22 03:45 AM
11/29/22 03:45 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's the one that unloads the air pressure from going back to the compressor if what I see is correct.
It should be just a basic one way valve that's spring loaded.
Any one that you can thread in should work fine.
As long as it allows pressure from the compressor to go through and seals to block it back flowing is all that matters.
If you can't find the correct exact one, adapting one may be required.
Re: Air compressor check valve question(s) [Re: SNK-EYZ] #3097994
11/29/22 05:52 AM
11/29/22 05:52 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am having trouble grasping how your compressor is tubed from your pictures. Where is your unloader valve, on the pressure switch or on the end of the compressor crankshaft?
Re: Air compressor check valve question(s) [Re: 6PakBee] #3098017
11/29/22 09:00 AM
11/29/22 09:00 AM
6PakBee, I don't have any other pictures of it and the compressor isn't close by........
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3098018
11/29/22 09:06 AM
11/29/22 09:06 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Air compressor check valve question(s) [Re: mopars4ever] #3098048
11/29/22 11:23 AM
11/29/22 11:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is the way I've seen most compressors tubed. The smaller ones usually have the unloader valve as part of the pressure switch. The larger ones have a centrifugally actuated unloader valve on the end of the crankshaft. They both bleed off the pressure on the upstream side of the check valve when the compressor stops so that the next start is with no pressure at the compressor pump discharge.
Re: Air compressor check valve question(s) [Re: 6PakBee] #3098051
11/29/22 11:32 AM
11/29/22 11:32 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The more I look at that I am starting to think that it isn't a check valve but a pressure relief valve. It's somewhat hard to tell but the seat that you see seems to be after all three connections.
Re: Air compressor check valve question(s) [Re: mopars4ever] #3098095
11/29/22 02:25 PM
11/29/22 02:25 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted by mopars4ever
That looks like what he needs.
Re: Air compressor check valve question(s) [Re: mopars4ever] #3098113
11/29/22 03:19 PM
11/29/22 03:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
"I say, Holmes, I think you have it."
Re: Air compressor check valve question(s) [Re: SNK-EYZ] #3098147
11/29/22 04:49 PM
11/29/22 04:49 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Isn't Central Pneumatic a Harbor Freight brand? Might check HF as well.
Re: Air compressor check valve question(s) [Re: Powerflow] #3098189
11/29/22 07:57 PM
11/29/22 07:57 PM
5thAve Offline
5thAve  Offline
The amazon one looks like the small fitting comes off the wrong side? But it's the right idea.
Re: Air compressor check valve question(s) [Re: 5thAve] #3098193
11/29/22 08:00 PM
11/29/22 08:00 PM
5thAve Offline
5thAve  Offline
Re: Air compressor check valve question(s) [Re: 6PakBee] #3098212
11/29/22 09:50 PM
11/29/22 09:50 PM
Been calling it what the manual refers to it as. The part is 'H' here. work
John
Re: Air compressor check valve question(s) [Re: 5thAve] #3098213
11/29/22 09:55 PM
11/29/22 09:55 PM
Good catch 5th! You are correct. I ordered the one you posted. thumbs
Thank you everyone for the help! It is much appreciated!
beer
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3098311
11/30/22 10:24 AM
11/30/22 10:24 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You were correct, it was the check valve. I just couldn't see the relationship of the three ports in the photos.
Re: Air compressor check valve question(s) [Re: 6PakBee] #3101409
12/11/22 08:02 PM
12/11/22 08:02 PM
Well, THAT didn't work out. The part I ordered thanks to 5thAve was the wrong size. Duh, I shoulda checked sizing. I take the blame on that one.
But now I have a bigger problem. I took a wire brush to the base of the fitting to clean off where it threaded into the tank then soaked it with PB Blaster for about a week. This did no good, the weight of my wrench broke the fitting off flush with the tank. flame
I know brass is a soft metal, but brittle?
*sigh*
So now I'm at the crossroads of do I keep jacking with this thing or spend money I don't have and get another compressor?
frowwn
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3101411
12/11/22 08:10 PM
12/11/22 08:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
FB Marketplace is your friend !!
Re: Air compressor check valve question(s) [Re: Stanton] #3101426
12/11/22 08:42 PM
12/11/22 08:42 PM
I just worry that I'll end up buying someone's problem...... nervous
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3101504
12/12/22 06:48 AM
12/12/22 06:48 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Lay the compressor on its side and take a hacksaw blade and make two cuts 180 degrees apart in the brass fitting just down to the threads. Then take a small chisel and peel the remains of the fitting out of the tank. Removed a number of large brass fittings like this. Just don't get carried away with the cuts or you'll have another problem.
Re: Air compressor check valve question(s) [Re: 6PakBee] #3101782
12/12/22 11:47 PM
12/12/22 11:47 PM
5thAve Offline
5thAve  Offline
That sucks!
I had a portable compressor given to me for free because it had a rusted out tank. I ended up finding another one for $20 that had compressor problems but the tank was good. Swapped the compressor parts from the bad tank to the good one and all is good now. So sometimes buying someone elses problem isn't necesserily a bad thing!
