Air compressor check valve question(s)
#3097973
11/29/22 12:28 AM
11/29/22 12:28 AM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
I've got a Brute 15 gal 125psi compressor I picked up for cheap almost 10 yrs ago. For my occasional use, it has served me well. This past weekend, the check valve failed, as in, it came apart. The pressure regulator failed in a similar manner not long after I bought the unit (chinese high quality.....) The exact replacement is no longer available (of course). So my question is: Are all check valves basically the same, meaning, can I use a 'universal' type one in its place? (A new compressor is out of the question right now, and this unit otherwise works fine). Thanks!
John
Re: Air compressor check valve question(s)
[Re: SattyNoCar]
#3097989
11/29/22 03:45 AM
11/29/22 03:45 AM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
That's the one that unloads the air pressure from going back to the compressor if what I see is correct. It should be just a basic one way valve that's spring loaded.
Any one that you can thread in should work fine. As long as it allows pressure from the compressor to go through and seals to block it back flowing is all that matters.
If you can't find the correct exact one, adapting one may be required.
[Re: SNK-EYZ]
#3097994
11/29/22 05:52 AM
11/29/22 05:52 AM
Posts: 10,732 North Dakota
6PakBee
North Dakota
I am having trouble grasping how your compressor is tubed from your pictures. Where is your unloader valve, on the pressure switch or on the end of the compressor crankshaft?
[Re: 6PakBee]
#3098017
11/29/22 09:00 AM
11/29/22 09:00 AM
SattyNoCar
6PakBee, I don't have any other pictures of it and the compressor isn't close by........
John
[Re: SattyNoCar]
#3098018
11/29/22 09:06 AM
11/29/22 09:06 AM
Posts: 13,601 md
mopars4ever
md
[Re: mopars4ever]
#3098048
11/29/22 11:23 AM
11/29/22 11:23 AM
6PakBee
North Dakota
This is the way I've seen most compressors tubed. The smaller ones usually have the unloader valve as part of the pressure switch. The larger ones have a centrifugally actuated unloader valve on the end of the crankshaft. They both bleed off the pressure on the upstream side of the check valve when the compressor stops so that the next start is with no pressure at the compressor pump discharge.
[Re: 6PakBee]
#3098051
11/29/22 11:32 AM
11/29/22 11:32 AM
6PakBee
North Dakota
The more I look at that I am starting to think that it isn't a check valve but a pressure relief valve. It's somewhat hard to tell but the seat that you see seems to be after all three connections.
[Re: mopars4ever]
#3098095
11/29/22 02:25 PM
11/29/22 02:25 PM
SNK-EYZ
A Red State
That looks like what he needs.
[Re: mopars4ever]
#3098113
11/29/22 03:19 PM
11/29/22 03:19 PM
6PakBee
North Dakota
"I say, Holmes, I think you have it."
[Re: SNK-EYZ]
#3098147
11/29/22 04:49 PM
11/29/22 04:49 PM
Posts: 1,296 New Jersey
Powerflow
New Jersey
That looks like what he needs. Isn't Central Pneumatic a Harbor Freight brand? Might check HF as well.
[Re: 5thAve]
#3098213
11/29/22 09:55 PM
11/29/22 09:55 PM
SattyNoCar
The amazon one looks like the small fitting comes off the wrong side? But it's the right idea. Good catch 5th! You are correct. I ordered the one you posted. Thank you everyone for the help! It is much appreciated!
John
[Re: SattyNoCar]
#3098311
11/30/22 10:24 AM
11/30/22 10:24 AM
6PakBee
North Dakota
The more I look at that I am starting to think that it isn't a check valve but a pressure relief valve. It's somewhat hard to tell but the seat that you see seems to be after all three connections. Been calling it what the manual refers to it as. The part is 'H' here. You were correct, it was the check valve. I just couldn't see the relationship of the three ports in the photos.
[Re: 6PakBee]
#3101409
12/11/22 08:02 PM
12/11/22 08:02 PM
SattyNoCar
Well, THAT didn't work out. The part I ordered thanks to 5thAve was the wrong size. Duh, I shoulda checked sizing. I take the blame on that one. But now I have a bigger problem. I took a wire brush to the base of the fitting to clean off where it threaded into the tank then soaked it with PB Blaster for about a week. This did no good, the weight of my wrench broke the fitting off flush with the tank. I know brass is a soft metal, but brittle? *sigh* So now I'm at the crossroads of do I keep jacking with this thing or spend money I don't have and get another compressor?
John
[Re: Stanton]
#3101426
12/11/22 08:42 PM
12/11/22 08:42 PM
SattyNoCar
FB Marketplace is your friend !! I just worry that I'll end up buying someone's problem......
John
[Re: SattyNoCar]
#3101504
12/12/22 06:48 AM
12/12/22 06:48 AM
6PakBee
North Dakota
Lay the compressor on its side and take a hacksaw blade and make two cuts 180 degrees apart in the brass fitting just down to the threads. Then take a small chisel and peel the remains of the fitting out of the tank. Removed a number of large brass fittings like this. Just don't get carried away with the cuts or you'll have another problem.
