Starter snout keeps breaking
#3097862
11/28/22 05:41 PM
11/28/22 05:41 PM
Posts: 7 Australia
Dartski68
Australia
In the last few years I have broken 3 Chinese mini starters Has anyone used the CVR starter with the solid steel snout? Or the similar MSD starters? 470 big block with 11to1 compression and 727 trans
Re: Starter snout keeps breaking
[Re: Dartski68]
#3097870
11/28/22 06:10 PM
11/28/22 06:10 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hate to say it but if you have broken three you have an alignment problem or something else you are missing.
[Re: Dartski68]
#3097897
11/28/22 07:34 PM
11/28/22 07:34 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I check the allingnment previously. I've cleaned the threads used a stud for the top with nyloc nut and she is a snug fit. I was running a low comp 440 previously for 10 years and the starter was fine. Same gear box too I thought it was also my optima battery was too small however a larger battery still didn't fix the problem When I turn the motor over without spark the starter spins nicely My dizzy isn't locked either So I'm assuming it's the starter not strong enough
I cut the nose off many of my powerglide setups. Have you ever tried that for the heck of it.
[Re: fbs63]
#3098016
11/29/22 08:59 AM
11/29/22 08:59 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Check for interference between the starter and the block. The C shaped section of the block that the starter fits in when bolted up sometimes touches the starter and won't let it tighten down flush (and square) on the trans case. I've found this to be the cause of breaking starters multiple times. Check for witness marks on the starter and block. Simply grind the block for clearance. this.
[Re: Sammy]
#3098083
11/29/22 01:47 PM
11/29/22 01:47 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I cut them off, never had an issue
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
