Starter snout keeps breaking #3097862
11/28/22 05:41 PM
11/28/22 05:41 PM
Australia
Dartski68 Offline OP
Australia
In the last few years I have broken 3 Chinese mini starters
Has anyone used the CVR starter with the solid steel snout?
Or the similar MSD starters?
470 big block with 11to1 compression and 727 trans
Re: Starter snout keeps breaking [Re: Dartski68] #3097870
11/28/22 06:10 PM
11/28/22 06:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Hate to say it but if you have broken three you have an alignment problem or something else you are missing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Starter snout keeps breaking [Re: Dartski68] #3097877
11/28/22 06:47 PM
11/28/22 06:47 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the depth engagement of the drive gear
Re: Starter snout keeps breaking [Re: rickraw] #3097887
11/28/22 07:15 PM
11/28/22 07:15 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
A friend broke three, found out the case was cracked around starter from the kick backs.
Re: Starter snout keeps breaking [Re: pittsburghracer] #3097895
11/28/22 07:29 PM
11/28/22 07:29 PM
Australia
Australia
I check the allingnment previously. I've cleaned the threads used a stud for the top with nyloc nut and she is a snug fit.
I was running a low comp 440 previously for 10 years and the starter was fine. Same gear box too
I thought it was also my optima battery was too small however a larger battery still didn't fix the problem
When I turn the motor over without spark the starter spins nicely
My dizzy isn't locked either
So I'm assuming it's the starter not strong enough
Re: Starter snout keeps breaking [Re: Dartski68] #3097897
11/28/22 07:34 PM
11/28/22 07:34 PM
PA.
"Little"John
"Little"John
PA.
I cut the nose off many of my powerglide setups. Have you ever tried that for the heck of it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Starter snout keeps breaking [Re: pittsburghracer] #3097899
11/28/22 07:39 PM
11/28/22 07:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Don't give it gas wile its cranking.
Re: Starter snout keeps breaking [Re: FastmOp] #3097998
11/29/22 07:43 AM
11/29/22 07:43 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
what i have found, after breaking a snout, is the top mounting hole in the starter is made for a 1/2" fastener vs a stock (big block) 7/16" fastener. the starter index's on the snout and with the loose fitting top bolt hole and some starter kick back the snout cracks. since then, i put a sleeve in the top hole to accommodate the 7'16" bolt and that keeps the starter located. no more broken snouts. another option would be a stepped stud for the top hole; 1/2" to 7/16".
Re: Starter snout keeps breaking [Re: lewtot184] #3098002
11/29/22 08:02 AM
11/29/22 08:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Check for interference between the starter and the block. The C shaped section of the block that the starter fits in when bolted up sometimes touches the starter and won't let it tighten down flush (and square) on the trans case. I've found this to be the cause of breaking starters multiple times. Check for witness marks on the starter and block. Simply grind the block for clearance.
Re: Starter snout keeps breaking [Re: fbs63] #3098016
11/29/22 08:59 AM
11/29/22 08:59 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
this.
Re: Starter snout keeps breaking [Re: TRENDZ] #3098019
11/29/22 09:13 AM
11/29/22 09:13 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Use the recommended male stud in the top starter hole.
Re: Starter snout keeps breaking [Re: Sammy] #3098083
11/29/22 01:47 PM
11/29/22 01:47 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I cut them off, never had an issue
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
