Re: Windage Trays...for big blocks
[Re: Harry's Taxi 2]
#3098622
12/01/22 10:43 AM
12/01/22 10:43 AM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I've used 2 of these.
https://bobmazzoliniracing.com/store/#!/Big-Block-Crank-Scraper/p/81474464/category=4301789 Cheap and "in stock". I wonder how much trimming it needs for a good fit...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3098733
12/01/22 06:28 PM
12/01/22 06:28 PM
Posts: 289 PA
Harry's Taxi 2
PA
https://bobmazzoliniracing.com/store/#!/Big-Block-Crank-Scraper/p/81474464/category=4301789 Cheap and "in stock". I wonder how much trimming it needs for a good fit... Needs a little trimming for a 4.15 crank. I trimmed it in the mill for a nicer finish.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Cab_Burge]
#3098756
12/01/22 07:32 PM
12/01/22 07:32 PM
Posts: 289 PA
Harry's Taxi 2
PA
Liny no worky i don't know how to make it a link. i just tried a copy and paste and that worked. https://bobmazzoliniracing.com/store/#!/Big-Block-Crank-Scraper/p/81474464/category=4301789
#3098761
12/01/22 07:40 PM
12/01/22 07:40 PM
Posts: 4,213 New York
polyspheric
New York
The cut-outs leave sharp edges, which will eventually develop in cracks as the pan flexes. Possible remedy:
Boffin Emeritus
[Re: Cab_Burge]
#3098863
12/02/22 08:38 AM
12/02/22 08:38 AM
Brad_Haak
Loudoun County, VA
... Better than dying, huh As one of my older bro's says, every day above ground is a good one
[Re: Hot 340]
#3098956
12/02/22 03:06 PM
12/02/22 03:06 PM
polyspheric
New York
My crude illustration (above) is also relevant to other physical shapes with sharp internal corners. Among these are modified K-members and crankshaft rod journals: if you can't obtain a radius as a safety, undercutting the intersection with a stop drill works very well.
Boffin Emeritus
[Re: moparx]
#3099035
12/02/22 06:37 PM
12/02/22 06:37 PM
polyspheric
New York
But... to add a radius, the existing surfaces must both be cut back by the radius dimension. This ruins the scraper, and changes the rod bearing size.
Boffin Emeritus
[Re: moparx]
#3099298
12/03/22 07:19 PM
12/03/22 07:19 PM
polyspheric
New York
On cranks, they cut a radius into the cheek adjacent to the rod journal (not the journal) so no finished machined surface is disturbed.
Boffin Emeritus
[Re: mopar dave]
#3099396
12/04/22 08:38 AM
12/04/22 08:38 AM
Posts: 2,937 A shed in England
Tig
A shed in England
After following this post and doing some research on windage including watching a couple vids from Engine Masters, I think my plan will be to get the Milodon 30931 pan with appropriate windage try for the 4.500 stroke and possibly a scraper. No fancy pans for me. If getting a scraper becomes to difficult than i simply wont use one. Thanks for posting because i had no plan of using a windage tray with this build before reading this post. Something else i learned with this windage research is there is as much HP to gain with scrapers and trays as there is with running less oil in the pan. Looks to me like some guys have too much oil in the pan. It's not the HP for me, that's a bonus, it's the dropping oil pressure in the shut down that gets me worried. I run a rudimentary scraper and wndage tray on a 4.50 stroke wedge, it still loses around 25 psi shutting down. I have to run a shallow pan, min level and also use an accumulator. We lose about 40psi with the 5.00 stroke wedge, no windage tray or scraper as we didn't have one to fit at the time. It's obviously aerating the oil, the bearings check out OK but I'd still rather it didn't do it at all.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3099401
12/04/22 09:02 AM
12/04/22 09:02 AM
Brad_Haak
Loudoun County, VA
Despite all the things I did to my pan, etc., I'm still waiting to find out if I have an issue w/ pressure loss after a full pass. If so, guess my next step is some form of oil accumulator to keep the system pressurized.
[Re: Tig]
#3099410
12/04/22 10:07 AM
12/04/22 10:07 AM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I would have to take a peak at my inside vids going down track, but as i remember i had about 55psi going down track and this is a 408, so 4.000 stroke. That would only be about a 5psi drop. It did not have a windage tray or scraper. My current 511with 4.250 stroke has a tray only and losses nothing going down track. It uses a milodon pump.
[Re: mopar dave]
#3099470
12/04/22 12:53 PM
12/04/22 12:53 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Keep in mind that windage trays and scrapers are two different things that do different jobs.
The scraper gets parasitic oil off the rotating assembly. That reduces weight and helps get the oil back to work. The portion of the scraper that is not scraping affects windage but in an unpredictable manner. There's still all kinds of buffeting and a hefty oil mist hurricane in the crankcase.
A windage tray is used to prevent that hurricane from frothing the oil in the pan. You need that bucket of oil down there to be on its best behavior. A relaxed pool is needed for more reliable pump pickup and steady pressure.
If winds are gusting to 60 mph you close the doors and windows, right?
Use the scraper to get oil off the spinny bits at high rpm. Use the tray to relax the oil in the pan. Use baffles to keep the oil near the pick up screen.
[Re: Hot 340]
#3099515
12/04/22 02:44 PM
12/04/22 02:44 PM
polyspheric
New York
A deep pan offers several advantages, of which the most obvious is more oil capacity. It also allow the oil to rest farther below the crank's spinning bits, and increases the air volume above the oil level. This acts as a buffer against crankcase pressure spikes.
Boffin Emeritus
