TORSION BAR SEALS #309729
05/06/09 11:52 AM
05/06/09 11:52 AM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
info or secrets on how to get the boots over the hex area of the bar.thanks.
Re: TORSION BAR SEALS [Re: FM370RR] #309730
05/06/09 11:53 AM
05/06/09 11:53 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
grease the heck out of it.
-Daty
Re: TORSION BAR SEALS [Re: FM370RR] #309731
05/06/09 12:12 PM
05/06/09 12:12 PM
PA
moparboy66 Offline
moparboy66  Offline
PA
I soaked them in boiling water to soften the rubber up, dried them, then swabbed a little grease inside.
Re: TORSION BAR SEALS [Re: FM370RR] #309732
05/06/09 01:31 PM
05/06/09 01:31 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
A few passes with the heat gun + a lot of grease worked for me.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: TORSION BAR SEALS [Re: Hrtbkr] #309733
05/06/09 02:19 PM
05/06/09 02:19 PM
AZ
FM370RR Offline OP
mopar addict
FM370RR  Offline OP
mopar addict
AZ
thanks
Re: TORSION BAR SEALS [Re: FM370RR] #309734
05/06/09 02:21 PM
05/06/09 02:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
heat them in the nuk box for a few seconds.. you wont believe how easy they go on then
I am truckless..
Re: TORSION BAR SEALS [Re: 340SHORTY] #309735
05/06/09 04:10 PM
05/06/09 04:10 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Here is what I did...
Go get a cheep funnel (I got a pack of 4 from the freight for 0.99), Cut the end off so it is the same dia as the t-bar - this creates a hard "wedge" you can use to slide the seal over the bar.
A little bit of grease and they slide right on...
I use the same approach for anything you have to slide something else...
If you have trouble holding it all together while putting the seal on, wrap a piece of tape around the t-bar and funnel to hold it on the end...
