Re: Radiator Electric Fan Set Ups, whatcha running? [Re: rickraw] #3096844
11/24/22 03:06 PM
11/24/22 03:06 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Don't forget the Mercedes fan swap from Moparts a while back.
https://board.moparts.org/ubbthread...c-cooling-fan-upgrade-long-w-photos.html
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: dvw] #3096897
11/24/22 06:26 PM
11/24/22 06:26 PM
moparx Offline
moparx  Offline
Originally Posted by dvw
Mine runs a late model junkyard Dodge Charger dual fan set-up. Easy to fit. They move a ton of air.
Doug
i'm fitting one of those OEM fans as well to my charger.
i agree, the OEM fans are what to use if you have the room ! up
beer
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: Mopar.70] #3096905
11/24/22 07:51 PM
11/24/22 07:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Puller only unless absolutely no way to fit in between the radiator and the engine.
Any radiator core not covered by the electric fan shroud should be masked on the engine side.
Boffin Emeritus
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: polyspheric] #3096920
11/24/22 09:29 PM
11/24/22 09:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
To add a bit...
Any electric fan shroud with large flat areas blocking the core should have flaps installed. They need to be top hinged so they lay flat and closed when stopped.
Air pushing through the radiator at speed will flip them open and allow air to get out. At low speed the electric fan will pull them closed and draw air through the radiator.
I can tell you that no matter the name on the box or the eleventy billion cfm marketing hype there is not an electric fan on the market drawing under 40 amps that can keep up with the massive volume of air slammed into a muscle-era car's grille at highway speed.
A tight shroud (read:pretty, slim, flat, close to the radiator core) will end up blocking air. If the store bought electric fan is powered up at speed it will not keep up with air flow and will become a 12 volt generator as the air flow overpowers it. Cutting flaps into the shroud will create a bypass that gives stacked up air an exit ramp.
People seem to forget that aerodynamics is at play between the radiator and shroud.
Look for OEM fans that fit your application. Dual fans can be handy for opening up some real estate in the center to allow a bit more room for the water pump.
- Stu Harmon
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: dvw] #3097043
11/25/22 02:03 PM
11/25/22 02:03 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Great looking set up. Thats the same fan I am useing on my 91 dakota sport .
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: 1980volare] #3097046
11/25/22 02:09 PM
11/25/22 02:09 PM
mopar65 Offline
mopar65  Offline
Originally Posted by 1980volare
I run a Taurus fan on a 26” aluminum radiator that’s under the trunk. It never gets over 180* the oem fans crush any aftermarket one. 90s Taurus fans are good, so are 98-02 camaro firebird fans.
thats the fan I used on my 73 big block dart. The fan worked awesome. But on my 91 dakota sport I ended up useing the fan set up from a 06 5.7 dodge charger. It has 2 fans and I needed the space between them so my electric water pump drive would clear.
Re: Radiator Electric Fan Set Ups, whatcha running? [Re: feets] #3097054
11/25/22 02:21 PM
11/25/22 02:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The ideal shroud covers the entire core face, then extends back as far as possible (1 foot at least) tapering down to the fan opening.
I can't think of any car with that much room.
Boffin Emeritus
