Bearing clearance on mains with BM aluminum block #3093650
11/12/22 09:18 AM
11/12/22 09:18 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I think i may start this 572 Hemi project over the winter getting into it over the holidays. I have the BM aluminum block with steel caps. What bearing clearances are needed on the main bearings? I will be using Callies steel rods, so i assume .030 on the rod bearings is fine?
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3093654
11/12/22 09:42 AM
11/12/22 09:42 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I like my engines a little loose, but I think .030 is way too much. Lol I am pretty sure you meant .003 which i would be fine with.
Joe
Without Data, you’re just another guy with an opinion.
Re: Bearing clearance on mains with BM aluminum block [Re: sr4440] #3093656
11/12/22 09:47 AM
11/12/22 09:47 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Yes .003 with an aluminum block is what I have mine set at. Be aware that when an aluminum block warms up you will see a drop in oil pressure at idle, lot more drop than an iron block. As far as I know that is normal and does not hurt anything.
Re: Bearing clearance on mains with BM aluminum block [Re: sr4440] #3093658
11/12/22 09:49 AM
11/12/22 09:49 AM
Mt Morris Michigan
Mt Morris Michigan
Yes .003" oops, .030 would be a bit much. I currently have my 511 at .0029 and everything seems fine after several seasons of street romping and a dozen trips down the track. Thanks for the correction.
Re: Bearing clearance on mains with BM aluminum block [Re: jwb123] #3093660
11/12/22 09:51 AM
11/12/22 09:51 AM
Mt Morris Michigan
Mt Morris Michigan
Yeah, the steel cap with the aluminum block had me guessing on clearance. Want to be sure to get that right.
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3093698
11/12/22 12:57 PM
11/12/22 12:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The rods and crank are both steel, aluminum has nothing to do with it.
.003" is too loose for the rods, .0025"
Boffin Emeritus
Re: Bearing clearance on mains with BM aluminum block [Re: polyspheric] #3093702
11/12/22 01:09 PM
11/12/22 01:09 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have .0022-.0025 on my rods and .003 on my mains on my Hemi.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3093716
11/12/22 02:12 PM
11/12/22 02:12 PM
>003+ on the rods and .004+ on the main bearing in iron block with steel rods work well for me, I'm in the middle of assembling a new KB aluminum wedge block that has .0040+ on the mains and around .0027 + on the rods, I would feel a lot better with .003+ clearance on the Scat steel H beam rods. This motor has a set of CNC ported B1 heads with a sheet metal tunnel ram with two Mark Sullens E85 prep Dominator carbs, I'm going to try NOS on it starting with two kits, 150 on the small kit first and then, maybe, another 300 HP on the second kit if it will (the chassis) take it luck shruggy
I've never used any power adders so this will be the first time luck
My thinking on any HP or and race motors bearing clearances it is way better to have way to much bearing clearances than a TINY bit too little work
Re: Bearing clearance on mains with BM aluminum block [Re: Cab_Burge] #3093765
11/12/22 05:18 PM
11/12/22 05:18 PM
Mt Morris Michigan
Mt Morris Michigan
OK, so .003 on rods is good and .003-.004 on mains?
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3093816
11/12/22 09:44 PM
11/12/22 09:44 PM
up You betcha, works good, lasts a long time with 0W20WT standard Valvoline on the street making north of 700 HP and on the track with 10W30Wt (making near 800 HP) VR1 racing oil boogie up twocents
The new NOS motor will get those clearances and thin (VR10x30WT) oil also, I'm hoping it will make north of 1000 HP on E85 and then add another 150 to maybe 400 HP of NOS luck
Re: Bearing clearance on mains with BM aluminum block [Re: Cab_Burge] #3093878
11/13/22 10:02 AM
11/13/22 10:02 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, Thanks cab. I was under the impression that the 2 different expanding metals in the cap and the block would require something out of the norm for bearing clearance.
Thanks guys
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3093899
11/13/22 10:50 AM
11/13/22 10:50 AM
NC
440Jim Offline
440Jim  Offline
NC
I guess I run my bearing clearances tighter than some racers. 10W-30 racing oil
My previous KB aluminum block had almost identical clearances and never an issue.
BMP aluminum block, steel rods, Callies magnum crank.
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3094066
11/14/22 03:42 AM
11/14/22 03:42 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Do aluminum block engines require additional main and rod oil clearances? If so, can someone explain why?
I've built a lot of (iron block) engines throughout the years and typically shoot for .002-.0025" on my Mains and .0015-.002" on my Rods. Obviously application and rod journal sizes matter here. I'm talking hot street engines, not full race.
On a race engine I wouldn't be afraid to run .003-.0035" on the Mains and .002-.0025" on the Rods, but I don't see a need for more oil clearance than that.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Bearing clearance on mains with BM aluminum block [Re: BigDaddy440] #3094071
11/14/22 08:28 AM
11/14/22 08:28 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
No
Re: Bearing clearance on mains with BM aluminum block [Re: mopar dave] #3094089
11/14/22 09:39 AM
11/14/22 09:39 AM
an8sec70cuda Offline
Mine has .0035" on the mains and about .0027" on the rods (steel), if I recall correctly. Don't have my folder here where I keep everything written down.
Mine is a KB block FWIW. Been running it that way since 2006.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bearing clearance on mains with BM aluminum block [Re: an8sec70cuda] #3094097
11/14/22 09:53 AM
11/14/22 09:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I suscribe to the .001"/1.00" clearance/diameter theory. Any tighter is an experiment. Like trying lower oil pressure. Will it work? Maybe? But what advantage is it? As far as going larger. I see no trouble with that either. Oil needs to take away heat and provide a hydro dynamic wedge between the parts. As long as the pump has enough volume to keep a steady flow it's good. At worst .001"-.0015" larger will reduce idle oil pressure. Oil pressure reduction will be far more extreme with loose lifter bores, large push rod holes (pushrod oiling), and large oil feed lines(indy head) than from bearing clearance. Years ago I built and engine with .004"/.004" bearing clearnce. It only would reach 45psi hot with a high volume pump with a external adjuster turned all the way in. So I took it apart andinstalled .001" tighter bearings. The result? no change. Turned out the pushrod holes were so large (.090") that the pump couldn't keep up. Reduced the pushrod size to .045 with roll pins. Had to back the screw all the way out. Then cut a coil off the spring.
Doug
Re: Bearing clearance on mains with BM aluminum block [Re: dvw] #3094132
11/14/22 01:30 PM
11/14/22 01:30 PM
NY
challenger451ci Offline
NY
I setup my aluminum Indy Maxx with 0.0035" - 0.0038" on the mains with 400 journals. Number 4 main(0.0038") was not happy when I tore it down after about 100 passes and that journal had about 0.0008" runout. The rod bearings looked perfect and the rest of the mains(except the back half of #3) looked very good considering the number of passes and street miles I had on it. I talked to Molnar and they said 0.0038" might have been a bit too much with the expansion of the aluminum block and allowed the crank to whip killing the #4 main. Given Molar's good reputation, I couldn't argue his logic. This time around I went with a Callies crank and had the block line bored for 440 mains. It's clearanced at 0.003" on the mains now.
Re: Bearing clearance on mains with BM aluminum block [Re: challenger451ci] #3094139
11/14/22 01:43 PM
11/14/22 01:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I would shoot for .0030" ish for main clearance. Will depend on the final application, mainly street, street/strip, strip/street or just a race car. Rods depends again on material being used. And by all means restrict that oil going up top. I have my stuff down to .029" restrictors and there is still PLENTY of oil up top. And yes you will loose oil pressure when its warm. Just like an iron block will how much is a guess at best as they all seem yo vary and I have used nothing but aluminum blocks pretty much for the last 12 years.
