Re: Bearing clearance on mains with BM aluminum block
[Re: mopar dave]
#3093654
11/12/22 08:42 AM
11/12/22 08:42 AM
Posts: 663 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I think i may start this 572 Hemi project over the winter getting into it over the holidays. I have the BM aluminum block with steel caps. What bearing clearances are needed on the main bearings? I will be using Callies steel rods, so i assume .030 on the rod bearings is fine? I like my engines a little loose, but I think .030 is way too much. Lol I am pretty sure you meant .003 which i would be fine with. Joe
Without Data, you’re just another guy with an opinion.
[Re: mopar dave]
#3093698
11/12/22 11:57 AM
11/12/22 11:57 AM
Posts: 4,077 New York
polyspheric
New York
The rods and crank are both steel, aluminum has nothing to do with it. .003" is too loose for the rods, .0025"
Boffin Emeritus
[Re: polyspheric]
#3093702
11/12/22 12:09 PM
11/12/22 12:09 PM
Posts: 4,107 Motor City
6PKRTSE
Motor City
I have .0022-.0025 on my rods and .003 on my mains on my Hemi.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3093716
11/12/22 01:12 PM
11/12/22 01:12 PM
Posts: 40,889 Bend,OR USA
Cab_Burge
>003+ on the rods and .004+ on the main bearing in iron block with steel rods work well for me, I'm in the middle of assembling a new KB aluminum wedge block that has .0040+ on the mains and around .0027 + on the rods, I would feel a lot better with .003+ clearance on the Scat steel H beam rods. This motor has a set of CNC ported B1 heads with a sheet metal tunnel ram with two Mark Sullens E85 prep Dominator carbs, I'm going to try NOS on it starting with two kits, 150 on the small kit first and then, maybe, another 300 HP on the second kit if it will (the chassis) take it  I've never used any power adders so this will be the first time  My thinking on any HP or and race motors bearing clearances it is way better to have way to much bearing clearances than a TINY bit too little
[Re: mopar dave]
#3093816
11/12/22 08:44 PM
11/12/22 08:44 PM
Cab_Burge
[Re: mopar dave]
#3093899
11/13/22 09:50 AM
11/13/22 09:50 AM
Posts: 16,790 Western NC
440Jim
Western NC
I guess I run my bearing clearances tighter than some racers. 10W-30 racing oil My previous KB aluminum block had almost identical clearances and never an issue. BMP aluminum block, steel rods, Callies magnum crank.
1993 Daytona, 1973 Cuda 440, 2009 Challenger 5.7 Hemi, 2015 RAM 1500 5.7 Hemi 8-speed auto, Link to 572 B1 - Part 1
[Re: mopar dave]
#3094066
11/14/22 02:42 AM
11/14/22 02:42 AM
Posts: 673 California
BigDaddy440
California
Do aluminum block engines require additional main and rod oil clearances? If so, can someone explain why?
I've built a lot of (iron block) engines throughout the years and typically shoot for .002-.0025" on my Mains and .0015-.002" on my Rods. Obviously application and rod journal sizes matter here. I'm talking hot street engines, not full race.
On a race engine I wouldn't be afraid to run .003-.0035" on the Mains and .002-.0025" on the Rods, but I don't see a need for more oil clearance than that.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#3094071
11/14/22 07:28 AM
11/14/22 07:28 AM
Posts: 1,619 Apollo, PA.
B1MAXX
Apollo, PA.
Do aluminum block engines require additional main and rod oil clearances? If so, can someone explain why? . No
[Re: mopar dave]
#3094089
11/14/22 08:39 AM
11/14/22 08:39 AM
Posts: 12,936 Marion, South Carolina [><]
an8sec70cuda
Mine has .0035" on the mains and about .0027" on the rods (steel), if I recall correctly. Don't have my folder here where I keep everything written down. Mine is a KB block FWIW. Been running it that way since 2006.
CHIP '70 hemicuda...8 sec street car '69 road runner 440-6, 4 speed '71 Demon 340 '73 Chrysler New Yorker '90 Chevy 454SS Silverado '06 GMC 2500HD LBZ Duramax...toy hauler
[Re: challenger451ci]
#3094139
11/14/22 12:43 PM
11/14/22 12:43 PM
Posts: 18,798 Las Vegas
Al_Alguire
Las Vegas
FWIW I would shoot for .0030" ish for main clearance. Will depend on the final application, mainly street, street/strip, strip/street or just a race car. Rods depends again on material being used. And by all means restrict that oil going up top. I have my stuff down to .029" restrictors and there is still PLENTY of oil up top. And yes you will loose oil pressure when its warm. Just like an iron block will how much is a guess at best as they all seem yo vary and I have used nothing but aluminum blocks pretty much for the last 12 years.
