Sb. Std rpm vs stealth intake. #3092899
11/09/22 04:27 PM
11/09/22 04:27 PM
CA.
RAY1969CARS Offline OP
CA.
Has anybody ever had these two intakes up against each other? The standard small block.rpm and the Weiand Stealth any info
Thank you mopar or no car
Re: Sb. Std rpm vs stealth intake. [Re: RAY1969CARS] #3092960
11/09/22 08:21 PM
11/09/22 08:21 PM
CA
crackedback Offline
crackedback  Offline
CA
RPM window is larger by a smidge.
I've had distribution issues with the Stealth requiring offset jetting, more jet on the deep plenum side.
I doubt you are going to see a huge difference between the two intakes.
