Re: anyone ever vinyl boat storage wrap a car?
[Re: A12]
#3092476
11/08/22 01:12 AM
11/08/22 01:12 AM
Posts: 8,399 Highland, MI.
Sunroofcuda
Highland, MI.
Bad idea if a car is being kept stored outside. Holds moisture in.
[Re: Sunroofcuda]
#3092488
11/08/22 07:36 AM
11/08/22 07:36 AM
Posts: 11,413 NJ
rdrnr6970
Your #1 source for current events
NJ
Alotta boats around here get wrapped,but I've never ever seen a car get wrapped.I don't think it's a good idea.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: Sunroofcuda]
#3092489
11/08/22 07:42 AM
11/08/22 07:42 AM
Posts: 999 rust belt
Moparite
rust belt
I have one of these It's not supposed to be used for outdoors but you can. I got a car cover to put on so the paint doesn't get marked up and then put a tarp over the bag. The tarp helps keep the sun from damaging the bag. You can buy moisture absorbing things from them to keep the moisture out or buy a few damp rids and put them in there. I have been looking for a decent outdoor 100% water proof bag but it doesn't exist. Someone should make one that doesn't cost $500+.
[Re: A12]
#3092515
11/08/22 10:07 AM
11/08/22 10:07 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
In the past we used a "car in a bag" deal that you literally push the car into, then leave a bunch of desiccant bags (5 lbs each, maybe?) in it, then extract as much air as possible and clamp it closed for the duration.
Did it work? Yep
Was it a big PITA? Yep
No way I'd just cover a car w/ that type of material w/o expecting "bad things" to happen during the storage, though.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Sunroofcuda]
#3092649
11/08/22 06:40 PM
11/08/22 06:40 PM
Posts: 4,154 Canada -- Posts: 4034 -Registe...
5thAve
Bad idea if a car is being kept stored outside. Holds moisture in. Yeah boats can take the moisture. With a car you could end up with rust starting all over the place.
