Re: Starter thermal wrap?
[Re: moparx]
#3091440
11/03/22 03:31 PM
11/03/22 03:31 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
is Zircoflex self adhesive ? Yes it is.
[Re: BDW]
#3092554
11/08/22 12:50 PM
11/08/22 12:50 PM
INTMD8
Lake Villa Il
Check voltage at starter lug when cranking and then the battery.
(Make sure you don't have a big drop across a cable or cable end)
[Re: INTMD8]
#3092600
11/08/22 03:49 PM
11/08/22 03:49 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Bad or insufficient grounds cause many problems.
Carl Kessel
[Re: CKessel]
#3092617
11/08/22 04:44 PM
11/08/22 04:44 PM
Posts: 19,499 north of coder
moparx
Bad or insufficient grounds cause many problems. my first thought as well. as has already been said, check for voltage drop on all wires to the starter. this includes the small wires used for the switch, button, etc. if you have "bolt on/temporary" battery cable ends, get rid of them ! [not saying you do, but i have seen more electrical problems stemming from those things it's funny i have any hair left on my head] if the wiring is more than a few years old, look over the terminals at the connections for any "green death" that may be wicking into the strands from a nick or cut in the insulation. please let us know what you find.
[Re: BDW]
#3092793
11/09/22 10:45 AM
11/09/22 10:45 AM
INTMD8
Lake Villa Il
What size cables? Big ground from engine to chassis as well?
Posting photos of everything may help.
