What AN hose ?
#3091504
11/03/22 10:07 PM
11/03/22 10:07 PM
Posts: 4,701 On the parachute mount
n20mstr
So many choices out there . I have used almost all of them …except the really “good” ones . Now I’m looking at Earls ultrapro . Seems really nice PTFE and very Flexible and looks long lasting , easy to assemble .
BUT , it doesn’t come in -8 ? I need -8 for fuel rail feed and return . Or am I missing something??
....BAD A$$ STREET CAR.....
Re: What AN hose ?
[Re: n20mstr]
#3091521
11/03/22 10:54 PM
11/03/22 10:54 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
I like Goodridge 910, ptfe
Re: What AN hose ?
[Re: n20mstr]
#3091543
11/04/22 05:57 AM
11/04/22 05:57 AM
Posts: 289 PA
Harry's Taxi 2
PA
1-Aeroquip 2-Earls 3-Fragola
In that order
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: What AN hose ?
[Re: justinp61]
#3091552
11/04/22 07:47 AM
11/04/22 07:47 AM
n20mstr
I use the Earls Pro Lite 350. Being that its not PTFE , how long does it last?? Im only asking because i want to use it to plumb the fuel rails and dont want any problems with injectors. Also the 65 psi fuel pressure is OK??
Re: What AN hose ?
[Re: n20mstr]
#3091565
11/04/22 09:10 AM
11/04/22 09:10 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I like the Fragola stuff, supposedly all USA made fittings and all.
68 Barracuda Formula S 340
Re: What AN hose ?
[Re: n20mstr]
#3091578
11/04/22 10:29 AM
11/04/22 10:29 AM
INTMD8
Lake Villa Il
I use the Earls Pro Lite 350. Being that its not PTFE , how long does it last?? Im only asking because i want to use it to plumb the fuel rails and dont want any problems with injectors. Also the 65 psi fuel pressure is OK?? I ran that hose on an EFI car in the past and wouldn't again. Entire garage smelled like fuel. Allows fumes to pass through.
Re: What AN hose ?
[Re: INTMD8]
#3091599
11/04/22 12:02 PM
11/04/22 12:02 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I use the Earls Pro Lite 350. Being that its not PTFE , how long does it last?? Im only asking because i want to use it to plumb the fuel rails and dont want any problems with injectors. Also the 65 psi fuel pressure is OK?? I ran that hose on an EFI car in the past and wouldn't again. Entire garage smelled like fuel. Allows fumes to pass through. I would change that out now to prevent an explosion from the fumes igniting when it gets warmer You know how Murphy loves messing with us
Re: What AN hose ?
[Re: INTMD8]
#3091609
11/04/22 12:40 PM
11/04/22 12:40 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Another vote for Fragola, made in USA!
Re: What AN hose ?
[Re: Al_Alguire]
#3091612
11/04/22 12:45 PM
11/04/22 12:45 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
All fragola on my car. I do have thousands of fittings in bins full of Earls, Aeroquip, Red Horse, Vibrant and XRP.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: What AN hose ?
[Re: n20mstr]
#3091623
11/04/22 01:36 PM
11/04/22 01:36 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I use the Earls Pro Lite 350. Being that its not PTFE , how long does it last?? Im only asking because i want to use it to plumb the fuel rails and dont want any problems with injectors. Also the 65 psi fuel pressure is OK?? I don't run fuel injection so I can't comment on high pressure. I've had it on my Dart for about 11 years and have never had any issues, my shop doesn't smell like gas either.
Re: What AN hose ?
[Re: Cab_Burge]
#3091626
11/04/22 02:03 PM
11/04/22 02:03 PM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've used Aeroquip for years. Used Fragola on the last car after looking at their catalog and hearing all the love for their stuff. Now I like them too.
Their PTFE is a Series 6000. Available up to -12. Price is in line with others or even a little cheaper. Made in Connecticut by a family owned business.
Re: What AN hose ?
[Re: Cab_Burge]
#3091670
11/04/22 05:04 PM
11/04/22 05:04 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I agree with Cab. I had cheap Chinese fittings and line on my car when I was converting it to EFI. When I was checking the system one fitting failed and several other leaks. Within a second there was 2 to 3 L of fuel all over my engine compartment. I’m glad the car was not running or it would’ve burnt to the ground. I will never use Chinese fittings again. Fragola fittings and hoses are made in the USA!
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: What AN hose ?
[Re: CMcAllister]
#3091671
11/04/22 05:07 PM
11/04/22 05:07 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I prefer crimped hose fittings. My last two cars were done with all Brown & Miller Racing Solutions (BMRS) https://bmrs.net/ As for reusable fittings and hose I use Fragola.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Re: What AN hose ?
[Re: Plumb Wired]
#3091740
11/04/22 09:51 PM
11/04/22 09:51 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
Of the AN PTFE lines I've bought recently, definitely been happiest with the Fragola hose and fittings.
I'll have to give the Goodridge stuff a try though, looks like Pegasus carries them.
Re: What AN hose ?
[Re: Plumb Wired]
#3092016
11/06/22 02:47 PM
11/06/22 02:47 PM
Posts: 912 London, England
mopar_mark
London, England
I prefer crimped hose fittings. My last two cars were done with all Brown & Miller Racing Solutions (BMRS) https://bmrs.net/ As for reusable fittings and hose I use Fragola. Brown & Miller crimped for me too, expensive but I think the quality justifies the extra expense.
