what trans brake is this please? #3091012
11/01/22 07:58 PM
11/01/22 07:58 PM
delhi,il
trw1982 Offline OP
trw1982  Offline OP
delhi,il
a buddy of mine got this trans from a guy that was too much in the burn out box. bent the output shat approx 45 deg. i am replacing the broken parts i.e. output shaft, ext housing, gov support and a few small parts. it air checked good and bands look good. clutches are also ok. please pay particular attention to the solenoid, the alum block it is bolted to, the seperator plate is an 1/8 alum plate that has been cut out with a jig saw and cleaned up with a wizzer tool. anyone seen anything like this before? tia
Re: what trans brake is this please? [Re: trw1982] #3091030
11/01/22 09:46 PM
11/01/22 09:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
A lot of brakes were “crafted” from stock parts “massaged” to work their magic. This in and older Griner and a Pro Trans brake. I’ve also had a Transact brake that had the larger solenoid like the Griner. Can’t say I know who’s handy work that is.
Re: what trans brake is this please? [Re: trw1982] #3091045
11/01/22 11:13 PM
11/01/22 11:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Might be a turbo action
Re: what trans brake is this please? [Re: trw1982] #3091111
11/02/22 10:56 AM
11/02/22 10:56 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
I believe it is a TransKing
It should have low band apply and fluid release brake valve
I think they are in New Caney, TX
Gilbert is the valve body tech
Some old phone numbers I’ve seen posted
281 689 0117
936 520 8113
Re: what trans brake is this please? [Re: J_BODY] #3091131
11/02/22 12:17 PM
11/02/22 12:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
And, as an FYI, the ProTrans brake is A&A.
Re: what trans brake is this please? [Re: rickraw] #3091148
11/02/22 12:47 PM
11/02/22 12:47 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
All TA stuff is hand engraved on the edge of the separator plate with the PN and serial number so it is readable when installed in the car if you have the pan off. TA has always been super helpful in decoding the serial number as to the date of the build and if it is good to use as is, or can be improved upon.
Re: what trans brake is this please? [Re: DusterW2] #3091151
11/02/22 12:50 PM
11/02/22 12:50 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
281 689 0117
936 520 8113
Looks like a Transking brake I had once....
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: what trans brake is this please? [Re: Leigh] #3091300
11/02/22 11:50 PM
11/02/22 11:50 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Incorrect…. Pro Trans brake was built in house.
Re: what trans brake is this please? [Re: J_BODY] #3091304
11/03/22 01:56 AM
11/03/22 01:56 AM
Pro Trans develop and manufacture a lot of race parts for 727,904 and their all out race 3 speed Pro Flites. They also whole sell a lot of their race parts to other tranny builders like A&A work
Good people, good PARTS up
Re: what trans brake is this please? [Re: Cab_Burge] #3091347
11/03/22 10:04 AM
11/03/22 10:04 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I believe A&A does as well. They have CNC machinery there for drums, etc, etc.
I was told a few years ago the two companies brakes were the same as they were jointly engineered, along with other “ shared” parts.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: what trans brake is this please? [Re: B3422W5] #3091351
11/03/22 10:12 AM
11/03/22 10:12 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
This is correct about A&A. Being that I am a distributor for A&A, I know they manufacture their aftermarket parts. To my knowledge, if they sell any other manufacturers aftermarket parts, that is something I am notified about upon placing an order.
