Re: Thoughts on Small block strokers [Re: Greenwood] #3091566
11/04/22 09:21 AM
11/04/22 09:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been real happy with the 418" my Dad and I built in 2015. It has somewhere around 7-10,000 miles on it and a few hundred passes, and 4 drag weeks now. The ring seal is still excellent and it usually sets a new best every year as other parts of the combo are refined.
It's an eagle forged crank with Molnar rods and Autotec pistons. Its a 10:1 pump gas deal. Its been 10.42@126.8 in my 3550lbs 68 Barracuda. I think 6.57@102.5 is its best 1/8th mile off the top of my head.
68 Barracuda Formula S 340
Re: Thoughts on Small block strokers [Re: Greenwood] #3091573
11/04/22 10:02 AM
11/04/22 10:02 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I gave been thinking of building a 408 out of My other 360 magnum engine I have. So thanks to the op fie making this post. To every one that has built one. What do you think about this kit. I think with my 60 cc trick flows I will have around 12.5.1 compression.
Scat 4340 Forged crank, 360 mains, 4.000 stroke
Scat H beam rods, 6.123 Length, ARP8740 rod bolts
Icon IC969-STD pistons ( standard 4.000 bore) this is a special order
Performance file to fit ring set
Clevite H series bearings
$2380.75 plus shipping
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Thoughts on Small block strokers [Re: mopar65] #3091627
11/04/22 02:06 PM
11/04/22 02:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Better have a real nice block with almost no miles if you want to run standard bore pistons. The stock piston ring does not go as high up the bore as most aftermarket pistons so any tiny imperfection will un-seat the ring at the top of the stroke and lose it's seal potentially costing power and MPG and reducing engine life.
Re: Thoughts on Small block strokers [Re: HotRodDave] #3091680
11/04/22 06:15 PM
11/04/22 06:15 PM
I've got most of the parts I need to build a 383 C.I. 360 stoker motor, new premium cast iron Mopar crankshaft from years ago offset ground down to SB Chevy 2.00 rod size, SB Chevy 6.125 long rods, the pistons need to be order along with the cam and so on.
I'll use a set of the Speed Master CNC ported aluminum heads with a single plane, maybe a dual plane intake, and make it for pump gas to sell to someone wanting a good motor (near 400 HP) at a reasonable price luck wrench
Probably be the last SB Mopar I'll build, Gen 3 hemi time devil wrench boogie
