Finding body filler #3090981
11/01/22 04:39 PM
11/01/22 04:39 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Best way to find body filler. And how much filler on a new painted car.
Re: Finding body filler [Re: bobs69] #3090995
11/01/22 06:25 PM
11/01/22 06:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Evercoat Rage or similar can be found at any autobody supply place. One gallon can should be enough to do a car easy.
Re: Finding body filler [Re: Neil] #3090996
11/01/22 06:45 PM
11/01/22 06:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What the scrap guys use to check for steel-iron
Re: Finding body filler [Re: bobs69] #3090997
11/01/22 06:45 PM
11/01/22 06:45 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
First learned to use a piece of wax paper and then 2 or 3 magnets of varying strength. Start by checking the places you'd expect to find filler used by hacks. (rockers, blower doors, around windows, and then crumple zones. Use the weakest magnet first and then work up to strongest. Once you get the feel a car can be checked out pretty quickly.
It's also possible to "map" a car using a infrared thermometer
Good shops will use only a skim after body work. I believe the manufacturers of the product say no more than 1/4".
I'd prefer to see 1/8" max at thickest.
Re: Finding body filler [Re: srt] #3091000
11/01/22 07:25 PM
11/01/22 07:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Ok, wasn't sure of the question the way it was worded. Lightweight magnets do work to tell where filler starts and stops.
Places to look:
Many shops will leave evidence of filler at the bottom of the car as nobody likes sanding down low. Common to find leftover lumps of filler and/or heavier sanding scratches along the very bottom and under the rocker panel edge etc. that you don't notice unless you look for it. Sight down the sides of the car looking all the way to the bottom for any waviness and then use the magnets to verify.
Knowledge of where the type of car your looking at is likely to rust are good places to start. If patch panels have been welded in then some filler is likely. If it's been fixed right the amount should be minimal.
Flashlight and mirror to check down the sides of the trunk extensions at the quarter panels and up under where the rear window channel is in case the rear window channel has been repaired. Some people use fiberglass and other methods to repair rust holes around window openings for a quick sale.
Speaking of the quarter panels the sound deadender finish should match on both sides. If someone has been into the quarters doing metal work they usually don't spend a lot of time making the trunk finishes look oem again.
Re: Finding body filler [Re: bobs69] #3091041
11/01/22 10:41 PM
11/01/22 10:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I bought one of these and believe it or not, I have found it to be very accurate. How? by verifying its readings on cars that were being stripped to bare metal. The thing dead nuts on eek
I thought it was a K-tel type thing (junk for the younger members), but have been quite impressed with it's accuracy on multiple cars.
Filler Detector
I've had mine for several years and do store it with the batteries out as I do with all battery tools that are not used regularly beer
I'd shop on the pricing wink beer
Re: Finding body filler [Re: srt] #3091140
11/02/22 12:34 PM
11/02/22 12:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If a shop can’t get a body straight with no SKIM COAT I’m going elsewhere.
Re: Finding body filler [Re: cudaman1969] #3091187
11/02/22 03:26 PM
11/02/22 03:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Nothing wrong with using body filler the way it was made to be used.
Most of those laser straight high end paint jobs are built up first with filler, either wipe on or spray on, before being blocked down.
The clowns that use it inches thick or try to fill rust holes with it give it a bad name.
Re: Finding body filler [Re: mgoblue9798] #3091201
11/02/22 04:51 PM
11/02/22 04:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Over time it fall out
Re: Finding body filler [Re: bobs69] #3091457
11/03/22 05:17 PM
11/03/22 05:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I use magnet backed dash plaques. Easy on paint and when they fail to stick I know there thick bondo. Usual places to find thick bondo is the rocker panels and lower quarter panels.
Abe Lincoln
Re: Finding body filler [Re: dart4forte] #3092259
11/07/22 11:44 AM
11/07/22 11:44 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
In my opinion, the straighter the car is, the more filler its going to have, albeit hopefully a skim coat. Save yourself some grief and don't bother looking unless the car looks like a mess and your looking for negotiation leverage.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Finding body filler [Re: turbobitt] #3092292
11/07/22 01:36 PM
11/07/22 01:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Agree. Old cars that have had all the body gaps tightened up to perfection like a new BMW are done by shops that like to cover whole cars with filler and sand them down like you see on the TV shows. It's ok if they would sand the majority of it back off, but sometimes they don't so you end up with straight metal that still has filler stacked on it for no reason.
