Random misfire code with popping from the exhaust #3090544
10/30/22 07:54 PM
10/30/22 07:54 PM
God's Country - Etowah, TN.
A34 Offline OP
A34  Offline OP
Hey guys,
My 2004, 5.7 is running rough and has a random misfire code. Initially I changed plugs and EGR valve as it was time for those, thinking that was it. It didn't fix the rough running and now the engine is making a popping sound from the exhaust when driving and not accelerating. It goes away on acceleration. Any ideas what that might be and how to diagnose it?
Thanks!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Random misfire code with popping from the exhaust [Re: A34] #3090556
10/30/22 09:38 PM
10/30/22 09:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My son's 5.7 had the same thing, found a bent pushrod. Replaced it and the misfire code, the rough idle and the motor noise all went away. Pull the valve covers and have a look.
Re: Random misfire code with popping from the exhaust [Re: A34] #3090563
10/30/22 10:19 PM
10/30/22 10:19 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Originally Posted by A34
Hey guys,
Thanks!
My 2016 Challenger Scat Pack did this a few weeks ago out of the blue - check engine light came on after a little while. I took it to a shop that scanned it & the code was showing "multiple misfire" - then he cleared the code & it has not done this again since.
Re: Random misfire code with popping from the exhaust [Re: Sunroofcuda] #3090579
10/30/22 11:27 PM
10/30/22 11:27 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a couple 4.6 fords that did that sort of thing and threw misfire codes. The coil on plugs had a boot that was rotted away on a few. I replaced them all on both cars when it happened and solved it all. Just a thought.
I want my fair share
Re: Random misfire code with popping from the exhaust [Re: SomeCarGuy] #3090601
10/31/22 06:54 AM
10/31/22 06:54 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
My run in with random misfire codes was broken valve springs. It costs nothing to pull the valve cover off and check the valve train while rotating the engine. If you have a way to test compression- thats even better. Start there. If your tests/inspection yield nothing, you may have to go into the engine. I personally have not seen an injector or coil pack throw a multiple misfire code, but I do not work on strictly chrysler products every single day.
Re: Random misfire code with popping from the exhaust [Re: moparjim79] #3090607
10/31/22 07:23 AM
10/31/22 07:23 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
As stated, check for broken valve springs.
The earlier Gen 3 Hemi's are kind of noted for broken valve springs when you start getting some miles on them.
It's supposedly from spring oscillation.
They started putting a stamped metal collar around the spring that went halfway up the spring in about 2006 to stop the spring oscillation to stop them from breaking.
Re: Random misfire code with popping from the exhaust [Re: SNK-EYZ] #3090707
10/31/22 01:54 PM
10/31/22 01:54 PM
moparx Offline
moparx  Offline
as i know nothing about the gen3 hemis, are the valve springs used on them beehive springs ?
TIA for educating this old dawg to new trix......... up bow
beer
Re: Random misfire code with popping from the exhaust [Re: moparx] #3090757
10/31/22 03:32 PM
10/31/22 03:32 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
beer
Yes they are beehive style springs.
I personally know of several people who have had the earlier valve springs break (besides myself).
Re: Random misfire code with popping from the exhaust [Re: SNK-EYZ] #3090821
10/31/22 08:41 PM
10/31/22 08:41 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
beer
There is a YouTube channel i watch sometimes- I Do Cars- the gentleman owns a automotive resale business- he buys core engines and tears them apart to see why they failed and goes from there. He made mention of something that made sense and made me cringe at the same time-" Thanks Chrysler for making valve springs a maintenance item". Haha
Re: Random misfire code with popping from the exhaust [Re: moparjim79] #3090844
10/31/22 10:28 PM
10/31/22 10:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A cranking compression test will not always show a broken or weak valve spring as it may have enough to contain "static" compression but not running with the pressure of combustion beer
Re: Random misfire code with popping from the exhaust [Re: A34] #3090936
11/01/22 12:26 PM
11/01/22 12:26 PM
A34 Offline OP
A34  Offline OP
Thanks for the tips guys!
I'll post an update when I get it figured out.
DEO VINDICE
Re: Random misfire code with popping from the exhaust [Re: TJP] #3091011
11/01/22 07:57 PM
11/01/22 07:57 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Agree 100%! A running compression test is the best way to pick out weak or broken valve springs. BTDT. Got my butt kicked around with a wandering misfire on a Vette many, many years ago. I now do running compression tests right after cranking compression tests. Learned the hard way.
Re: Random misfire code with popping from the exhaust [Re: Dcuda69] #3091020
11/01/22 08:47 PM
11/01/22 08:47 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Once again guys, thanks for clarification, I for one don't forget the conversation we all had a while ago about this, thats why I just generically coined compression test. No arguments here. And, waiting for update!
Re: Random misfire code with popping from the exhaust [Re: moparjim79] #3091207
11/02/22 04:58 PM
11/02/22 04:58 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
I had check engine light come on my 2010 hemi truck for misfire cylinder number 5. I replaced the coil pack and the code went away and has been running fine since then, and that was about five years ago.
