Random misfire code with popping from the exhaust
#3090544
10/30/22 07:54 PM
10/30/22 07:54 PM
Posts: 2,160 God's Country - Etowah, TN.
A34
Hey guys,
My 2004, 5.7 is running rough and has a random misfire code. Initially I changed plugs and EGR valve as it was time for those, thinking that was it. It didn't fix the rough running and now the engine is making a popping sound from the exhaust when driving and not accelerating. It goes away on acceleration. Any ideas what that might be and how to diagnose it?
Thanks!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Random misfire code with popping from the exhaust
[Re: A34]
#3090563
10/30/22 10:19 PM
10/30/22 10:19 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Hey guys,
Thanks! My 2016 Challenger Scat Pack did this a few weeks ago out of the blue - check engine light came on after a little while. I took it to a shop that scanned it & the code was showing "multiple misfire" - then he cleared the code & it has not done this again since.
[Re: Sunroofcuda]
#3090579
10/30/22 11:27 PM
10/30/22 11:27 PM
Posts: 10,226 Someplace you aren't
SomeCarGuy
I had a couple 4.6 fords that did that sort of thing and threw misfire codes. The coil on plugs had a boot that was rotted away on a few. I replaced them all on both cars when it happened and solved it all. Just a thought.
I want my fair share
[Re: moparjim79]
#3090607
10/31/22 07:23 AM
10/31/22 07:23 AM
Posts: 10,155 A Red State
SNK-EYZ
A Red State
My run in with random misfire codes was broken valve springs. It costs nothing to pull the valve cover off and check the valve train while rotating the engine. If you have a way to test compression- thats even better. Start there. If your tests/inspection yield nothing, you may have to go into the engine. I personally have not seen an injector or coil pack throw a multiple misfire code, but I do not work on strictly chrysler products every single day. As stated, check for broken valve springs. The earlier Gen 3 Hemi's are kind of noted for broken valve springs when you start getting some miles on them. It's supposedly from spring oscillation. They started putting a stamped metal collar around the spring that went halfway up the spring in about 2006 to stop the spring oscillation to stop them from breaking.
[Re: moparx]
#3090757
10/31/22 03:32 PM
10/31/22 03:32 PM
SNK-EYZ
A Red State
as i know nothing about the gen3 hemis, are the valve springs used on them beehive springs ? TIA for educating this old dawg to new trix......... Yes they are beehive style springs. I personally know of several people who have had the earlier valve springs break (besides myself).
[Re: SNK-EYZ]
#3090821
10/31/22 08:41 PM
10/31/22 08:41 PM
Posts: 1,410 Central Pa
moparjim79
Central Pa
as i know nothing about the gen3 hemis, are the valve springs used on them beehive springs ? TIA for educating this old dawg to new trix......... Yes they are beehive style springs. I personally know of several people who have had the earlier valve springs break (besides myself). There is a YouTube channel i watch sometimes- I Do Cars- the gentleman owns a automotive resale business- he buys core engines and tears them apart to see why they failed and goes from there. He made mention of something that made sense and made me cringe at the same time-" Thanks Chrysler for making valve springs a maintenance item". Haha
[Re: A34]
#3090936
11/01/22 12:26 PM
11/01/22 12:26 PM
A34
Thanks for the tips guys!
I'll post an update when I get it figured out.
DEO VINDICE
[Re: TJP]
#3091011
11/01/22 07:57 PM
11/01/22 07:57 PM
Posts: 4,956 WI
Dcuda69
WI
My run in with random misfire codes was broken valve springs. It costs nothing to pull the valve cover off and check the valve train while rotating the engine. If you have a way to test compression- thats even better. Start there. If your tests/inspection yield nothing, you may have to go into the engine. I personally have not seen an injector or coil pack throw a multiple misfire code, but I do not work on strictly chrysler products every single day. A cranking compression test will not always show a broken or weak valve spring as it may have enough to contain "static" compression but not running with the pressure of combustion Agree 100%! A running compression test is the best way to pick out weak or broken valve springs. BTDT. Got my butt kicked around with a wandering misfire on a Vette many, many years ago. I now do running compression tests right after cranking compression tests. Learned the hard way.
[Re: Dcuda69]
#3091020
11/01/22 08:47 PM
11/01/22 08:47 PM
moparjim79
Central Pa
My run in with random misfire codes was broken valve springs. It costs nothing to pull the valve cover off and check the valve train while rotating the engine. If you have a way to test compression- thats even better. Start there. If your tests/inspection yield nothing, you may have to go into the engine. I personally have not seen an injector or coil pack throw a multiple misfire code, but I do not work on strictly chrysler products every single day. A cranking compression test will not always show a broken or weak valve spring as it may have enough to contain "static" compression but not running with the pressure of combustion Agree 100%! A running compression test is the best way to pick out weak or broken valve springs. BTDT. Got my butt kicked around with a wandering misfire on a Vette many, many years ago. I now do running compression tests right after cranking compression tests. Learned the hard way. Once again guys, thanks for clarification, I for one don't forget the conversation we all had a while ago about this, thats why I just generically coined compression test. No arguments here. And, waiting for update!
