Manifold Destiny #3090005
10/28/22 06:58 PM
10/28/22 06:58 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Just curious which is the superior intake and how close they are performance wise. Edelbrock Performer or CH4B.
Re: Manifold Destiny [Re: elmor353] #3090028
10/28/22 07:51 PM
10/28/22 07:51 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
From a very old big block manifold shootout, what I recall is they're very close, almost indistinguishable, performance wise.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Manifold Destiny [Re: elmor353] #3090038
10/28/22 08:25 PM
10/28/22 08:25 PM
If I had to guess buy and use one it would be the RPM up twocents
Re: Manifold Destiny [Re: Cab_Burge] #3090060
10/28/22 09:45 PM
10/28/22 09:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by Cab_Burge
If I had to guess buy and sue one it would be the RPM up twocents
I would say it depends on the application and usage. shruggy
The standard Performer is rated at idle to 5500,
While the Performer RPM is 1500 to 6500.
The CH4B maybe in the middle. lot's of info on Google beer
Re: Manifold Destiny [Re: elmor353] #3090071
10/28/22 10:12 PM
10/28/22 10:12 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
https://www.motortrend.com/how-to/mopp-0207-intake-manifold-engine-and-rpm-range-test/
Per the above, the Performer RPM is a bit better overall than the CH4B. However, if hood clearance is an issue, the CH4B is closer to OEM height.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Manifold Destiny [Re: Brad_Haak] #3090081
10/28/22 10:29 PM
10/28/22 10:29 PM
PA
Scully Offline
Scully  Offline
PA
I tested the 68 440 mani, the CH4B and the TM7 at the track in 74 on a 426 street wedge with a small cam and 11" converter. The stock mani 13.37 the CH4B 13.34 and the TM7 12.98. This car was very repeatable within a couple of hundredths and I bracket raced it while I was building a new engine for my main race car.
Re: Manifold Destiny [Re: Cab_Burge] #3090202
10/29/22 01:58 PM
10/29/22 01:58 PM
moparx Offline
moparx  Offline
please don't "sue" the intake Cab......... laugh2 [just kidding !]
i think the RPM intake [both versions] may be the best bang for the buck, considering the CH4B seems to be getting a little hard to come by at times.
of course, having both intakes, i haven't looked for a while.
beer
Re: Manifold Destiny [Re: Scully] #3090339
10/29/22 10:07 PM
10/29/22 10:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quite a jump on that TM7 eek
Re: Manifold Destiny [Re: TJP] #3090343
10/29/22 10:15 PM
10/29/22 10:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Very motor combo dependent.
Of the Original Poster has a stock 440 with smaller than the factory HP 375 HP cam specs: 268/284 Duration, 0.450"/0.458" lift, 46 degrees overlap (115 LSA), installed at 113 Intake CL. And street gears like 3.23 or smaller.... the smaller Performer should be fine.
Even with that stock 383/440 HP cam the Performer RPM might be an improvement over the Performer.
Re: Manifold Destiny [Re: autoxcuda] #3090470
10/30/22 01:21 PM
10/30/22 01:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
AGREED wink beer
