Re: What's your preferred brand or style of collector gaskets?
[Re: Brad_Haak]
#3089797
10/28/22 05:47 AM
10/28/22 05:47 AM
Posts: 1,126 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Bleepin' exhaust system should have been done last night, but I think I got my dimensions wrong "just enough" to keep me from being able to line up the collector hookups w/ the tapered transitions to the x-pipe entries. Had the whole system on & off twice before giving up for the day.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: ZIPPY]
#3089929
10/28/22 02:32 PM
10/28/22 02:32 PM
Posts: 4,672 Wichita
GY3
Wichita
Jegs house brand copper collector gaskets have always worked well for me and been reusable.
V bands are the way to go if building new, though.
I have ball collectors that work great and don't require gaskets but I've been thinking about v-bands for ease of removal/assembly.
[Re: GY3]
#3089935
10/28/22 02:53 PM
10/28/22 02:53 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Flange flatness and clamp load (clean the threadings and slightly lube them... ant-seize preferred) is all that matters mostly... for any exhaust gasket to work. I use the Fel-Pro Performance collector gaskets... they are steel cored with compressible fiber facings, along with anti-stick coatings... easy release/removal... and re-use if needed.
I'm a former gasket applications engineer from Fel-Pro.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: GY3]
#3089991
10/28/22 06:01 PM
10/28/22 06:01 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I have ball collectors that work great and don't require gaskets but I've been thinking about v-bands for ease of removal/assembly. Yeah. One bolt rather than 3! We will see how it goes when mockups of the Hemi start, but if the low budget super comps I bought for mine require significant rework I'm definitely not above chopping the collector ring off and starting over with V band.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3090022
10/28/22 07:43 PM
10/28/22 07:43 PM
Brad_Haak
Loudoun County, VA
Exhaust comment(s) - here are the Brad-Fab collector 45-degree elbow hookups next to the NOT 45-degree elbow TTI parts - had to assemble the system w/ the stock pieces and will check w/ TTI about getting replacement pipes on which to perform the same mod - installed the "dead soft" aluminum gaskets... noticed there's a slight non-flat surface on one of the collector hookups and I could see light between the gasket and the mating surfaces; I "shaved" that corner of the gasket to enable the surfaces to mate, but...
[Re: moparx]
#3090147
10/29/22 10:18 AM
10/29/22 10:18 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
The ones on my Barracuda that I have to make my midpipe removable were done by a muffler shop mig, I have one on my conquest exhaust that a friend of mine did with my mig welder. I use my welder occasionally but I really have it so my friends can weld my stuff at my house lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3090217
10/29/22 02:47 PM
10/29/22 02:47 PM
Posts: 19,396 north of coder
moparx
The ones on my Barracuda that I have to make my midpipe removable were done by a muffler shop mig, I have one on my conquest exhaust that a friend of mine did with my mig welder. I use my welder occasionally but I really have it so my friends can weld my stuff at my house lol. thanks for the reply. i haven't had a V-band in my hand to examine, so i'm open to suggestions. as i have all the necessary parts here, i was going to use up what i already have. however, the parts i have are mild steel, so i was going to have the system coated after i got it together. if i was starting from scratch, i would buy stainless for all the more it is in cost over mild steel, plus the cost of having it coated makes the stainless choice a no-brainer.
[Re: moparx]
#3090393
10/30/22 08:33 AM
10/30/22 08:33 AM
Posts: 2,916 A shed in England
Tig
A shed in England
Slip on and V band. If you're running big bore ex system on a lowered car and need to keep it tight to the floorpan, there are some places under the car which can be a bit tight so a slip on in that area. V band clamps are used where I have the room. I can go from a 4 silencer x pipe system, to open headers and any other mix 'n match combo. But I generally race with X pipe, bullet mufflers and pre axle turn downs since we have a 120db limit at the track.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Brad_Haak]
#3091079
11/02/22 08:11 AM
11/02/22 08:11 AM
Brad_Haak
Loudoun County, VA
... - had to assemble the system w/ the stock pieces and will check w/ TTI about getting replacement pipes on which to perform the same mod ...
Talked to TTI yesterday. They don't normally sell the "slip connectors" separately from the x-pipe kits. However, "Mike" was helpful enough to go check in the shop for spares. He found there were some getting ready for the bender and opted to pull a finished set from a kit and will replace them w/ the parts in the process of being made. He also confirmed the left and right parts are different, so my attempt to use two identical 45-degree elbow wasn't gonna work, since I wasn't prepared to do additional and
