Re: HVAC guys: heat pump circuit board fuse blows, need advice
[Re: second 70]
#3089080
10/25/22 11:50 AM
10/25/22 11:50 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I found a geothermal guy who is going to come and look at it Friday. I'll see what he says. I don't know if he'll fix it or just try to sell me a new one.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: TJP]
#3089976
10/28/22 04:50 PM
10/28/22 04:50 PM
Hemi_Joel
Minnesota
The geothermal Tech showed up today. I definitely picked the right guy. He really knew what he was doing. He confirmed my diagnosis that that valve is shorted. He has worked on a lot of Econar geothermal heat pumps and hes going to look through his old inventory to see if he can find a valve. If not, he knows a guy who used to work at a Conner and hes going to call him up and see what valve could possibly be substituted. He doesn't have any R22, so he would pump the existing refrigerant into a new recycling container, then put it back in, and top off any shortage if needed with my tank. He said new heat pumps are on back order for 6 or 7 months.. So I really need to get this thing fixed to get me by for a while. He is also going to give me a quote for replacement heat pumps so maybe next Winter I'll have some new units in there.
[Re: second 70]
#3090325
10/29/22 09:20 PM
10/29/22 09:20 PM
Hemi_Joel
Minnesota
Glad you found someone who knows what their doing. Over the years by making plenty of mistakes I've found sometimes the cheapest fix is to hire someone that works on them everyday.
Mike It's a crapp shoot trying to find find somebody competent for something like this. I've hired incompetents to work on these in the past and it gets costly and frustrating. Most of the stuff I can usually do myself, but some of it is over my head. I got lucky this time. He did confirm that the new units are much more finicky, and are more prone to shut down if the water flow isn't just right and things like that. That has been my concern about replacing these.
