Setting cold valve lash w/aluminum block #3088748
10/24/22 06:51 AM
10/24/22 06:51 AM
MN
JERICOGTX Offline OP
MN
For those that have an aluminum block, how much tighter do you set your valve lash cold vs hot?
69 GTX 68 Road Runner
Re: Setting cold valve lash w/aluminum block [Re: JERICOGTX] #3088751
10/24/22 07:19 AM
10/24/22 07:19 AM
an8sec70cuda Offline
.013"-.014". This is on my KB block hemi.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Setting cold valve lash w/aluminum block [Re: an8sec70cuda] #3088753
10/24/22 07:28 AM
10/24/22 07:28 AM
MN
MN
You set them that much tighter, or to those numbers?
Re: Setting cold valve lash w/aluminum block [Re: JERICOGTX] #3088756
10/24/22 07:37 AM
10/24/22 07:37 AM
That much tighter. I usually set them at .008" lash cold.
CHIP
Re: Setting cold valve lash w/aluminum block [Re: JERICOGTX] #3088759
10/24/22 07:40 AM
10/24/22 07:40 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We run Aluminum block and heads and set lash .013-.014 tighter than specs on cam card So on our application the spec is .018 cold so we set them .005 cold.
Re: Setting cold valve lash w/aluminum block [Re: cl440] #3088760
10/24/22 07:42 AM
10/24/22 07:42 AM
See Jeff...I'm not crazy! grin grin
CHIP
Re: Setting cold valve lash w/aluminum block [Re: JERICOGTX] #3088763
10/24/22 07:52 AM
10/24/22 07:52 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We set ours .012" tighter than the cam card. Near enough what everyone else does. It's a wedge motor, Hemi heads might "grow" more due to the size of them but that's just a guess. We've checked it hot and the lash grows to what the card calls for (.024") perfectly. KB block, Indy 572-13 heads and Jesel rockers BTW
Re: Setting cold valve lash w/aluminum block [Re: an8sec70cuda] #3088764
10/24/22 07:59 AM
10/24/22 07:59 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
I set mine at .005 cold, too. That gave me about .023 or so hot when the cam card called out .020. But even the .005 was relative to 60+ temps.
Did anyone else see the EngineMasters episode the other night where they were playing around with different lashes? They picked up some noticeable ponies with a looser intake lash. Changing the exhaust both ways did little to nothing. Of course this was on a big block Shivvy, so.......... Still, it was interesting.
Master, again and still
Re: Setting cold valve lash w/aluminum block [Re: DaveRS23] #3088787
10/24/22 09:49 AM
10/24/22 09:49 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just don’t go crazy and start reving it up to 7000 rpm on start up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Setting cold valve lash w/aluminum block [Re: pittsburghracer] #3088791
10/24/22 09:57 AM
10/24/22 09:57 AM
central il.
second 70 Offline
second 70  Offline
central il.
Jeff Crane says Aluminum block and heads subtract .012" Iron block Al. heads subtract .006" Iron block and heads add .002"
But that's just a safe beginning. Like most others here I set mine tighter than that. Instead of the .006 they suggest I set mine at .012" cold to get the .020" I need on my al. heads.
Re: Setting cold valve lash w/aluminum block [Re: second 70] #3088828
10/24/22 12:11 PM
10/24/22 12:11 PM
iagree
You have to test each motor, not all of them will be the same.
Set them cold and then warm up the motor so you get around 160 F oil temps and pull one valve cover and check one set of valves to see what your motor needs wrench scope up Write it down also whistling grin
Re: Setting cold valve lash w/aluminum block [Re: an8sec70cuda] #3088831
10/24/22 12:27 PM
10/24/22 12:27 PM
NC
440Jim Offline
440Jim  Offline
NC
My experience with my BMP aluminum block, B1 heads, and 1.7 rocker ratio is the same. (180 to 70 deg)
Details:
Taller head (deck to rocker shaft) will expand more than shorter head (Edelbrock RPM).
Rocker ratio changes it a little, est 1.5 ratio using 0.012" changing to 1.7 ratio (1.7/1.5)x0.012 = 0.0136"
Difference between Cold and Hot temps changes lash. I use 0.00013" per degree temperature change.
50 deg F, 0.006" lash
70 deg F, 0.008" lash. (70-50) x0.00013 = 0.0026 lash change
180 deg, 0.023" lash. (180-50)x0.00013 = 0.017 lash change
200 deg, 0.026" lash. (200-50)x0.00013 = 0.020 lash change
Re: Setting cold valve lash w/aluminum block [Re: 440Jim] #3089037
10/25/22 05:40 AM
10/25/22 05:40 AM
MN
MN
Thanks for the advice everyone.
Struggling a little with the #6 rockers, as the roller isn't aligned with the valve tip. Some reason it's only a problem with that set of rockers. Spacers need to be shaved down some to make everything line up in the right spot.
Re: Setting cold valve lash w/aluminum block [Re: JERICOGTX] #3089084
10/25/22 11:09 AM
10/25/22 11:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I have run aluminum blocks for well over a decade and it will end up being between .013"-.020" cold. Most of mine have ended up .014-.016" in growth. My numbers are from low deck and tall deck KB's, Indys and World blocks FWIW
Re: Setting cold valve lash w/aluminum block [Re: Al_Alguire] #3089145
10/25/22 03:02 PM
10/25/22 03:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Setting my low deck Indymaxx block at 0.016 cold moves to 0.024 hot.
Re: Setting cold valve lash w/aluminum block [Re: rebel] #3089149
10/25/22 03:56 PM
10/25/22 03:56 PM
birdtracker Offline
birdtracker  Offline
setting my Indy block with Trick Flow heads and Harland Sharpe rockers at .010 cold nets .026 hot. Birdtracker
