Setting cold valve lash w/aluminum block
#3088748
10/24/22 07:51 AM
10/24/22 07:51 AM
Posts: 10,021 MN
JERICOGTX
MN
For those that have an aluminum block, how much tighter do you set your valve lash cold vs hot?
69 GTX
68 Road Runner
Re: Setting cold valve lash w/aluminum block
[Re: JERICOGTX]
#3088751
10/24/22 08:19 AM
10/24/22 08:19 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
.013"-.014". This is on my KB block hemi.
[Re: an8sec70cuda]
#3088753
10/24/22 08:28 AM
10/24/22 08:28 AM
Posts: 10,021 MN
JERICOGTX
MN
.013"-.014". This is on my KB block hemi. You set them that much tighter, or to those numbers?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3088756
10/24/22 08:37 AM
10/24/22 08:37 AM
an8sec70cuda
.013"-.014". This is on my KB block hemi. You set them that much tighter, or to those numbers? That much tighter. I usually set them at .008" lash cold.
[Re: cl440]
#3088760
10/24/22 08:42 AM
10/24/22 08:42 AM
an8sec70cuda
We run Aluminum block and heads and set lash .013-.014 tighter than specs on cam card So on our application the spec is .018 cold so we set them .005 cold. See Jeff...I'm not crazy!
[Re: JERICOGTX]
#3088763
10/24/22 08:52 AM
10/24/22 08:52 AM
Posts: 2,915 A shed in England
Tig
A shed in England
We set ours .012" tighter than the cam card. Near enough what everyone else does. It's a wedge motor, Hemi heads might "grow" more due to the size of them but that's just a guess. We've checked it hot and the lash grows to what the card calls for (.024") perfectly. KB block, Indy 572-13 heads and Jesel rockers BTW
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: an8sec70cuda]
#3088764
10/24/22 08:59 AM
10/24/22 08:59 AM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I set mine at .005 cold, too. That gave me about .023 or so hot when the cam card called out .020. But even the .005 was relative to 60+ temps.
Did anyone else see the EngineMasters episode the other night where they were playing around with different lashes? They picked up some noticeable ponies with a looser intake lash. Changing the exhaust both ways did little to nothing. Of course this was on a big block Shivvy, so.......... Still, it was interesting.
Master, again and still
[Re: DaveRS23]
#3088787
10/24/22 10:49 AM
10/24/22 10:49 AM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just don’t go crazy and start reving it up to 7000 rpm on start up.
[Re: an8sec70cuda]
#3088831
10/24/22 01:27 PM
10/24/22 01:27 PM
Posts: 16,923 NC
440Jim
NC
.013"-.014". This is on my KB block hemi. My experience with my BMP aluminum block, B1 heads, and 1.7 rocker ratio is the same. (180 to 70 deg) Details: Taller head (deck to rocker shaft) will expand more than shorter head (Edelbrock RPM). Rocker ratio changes it a little, est 1.5 ratio using 0.012" changing to 1.7 ratio (1.7/1.5)x0.012 = 0.0136" Difference between Cold and Hot temps changes lash. I use 0.00013" per degree temperature change. 50 deg F, 0.006" lash 70 deg F, 0.008" lash. (70-50) x0.00013 = 0.0026 lash change 180 deg, 0.023" lash. (180-50)x0.00013 = 0.017 lash change 200 deg, 0.026" lash. (200-50)x0.00013 = 0.020 lash change
[Re: 440Jim]
#3089037
10/25/22 06:40 AM
10/25/22 06:40 AM
Posts: 10,021 MN
JERICOGTX
MN
Thanks for the advice everyone.
Struggling a little with the #6 rockers, as the roller isn't aligned with the valve tip. Some reason it's only a problem with that set of rockers. Spacers need to be shaved down some to make everything line up in the right spot.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3089084
10/25/22 12:09 PM
10/25/22 12:09 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
FWIW I have run aluminum blocks for well over a decade and it will end up being between .013"-.020" cold. Most of mine have ended up .014-.016" in growth. My numbers are from low deck and tall deck KB's, Indys and World blocks FWIW
