Re: Cam and torque converter question
[Re: AndyF]
#3089458
10/26/22 06:07 PM
10/26/22 06:07 PM
Posts: 5,613 Detroit area
6PAX
Detroit area
Yeah you'll be happier in the long run with a smaller cam on the street and then a regular "high performance" converter. For your engine I'd recommend something like the old Mopar Performance 528 solid. That cam works great in a 470 high performance street engine. It is big enough to make good top end power, but it will also drive really nice with a typical high stall street converter. It isn't a race cam so don't buy a race converter, just stick with high performance street parts. Call Porter Racing Heads and tell them what you're trying to do and they'll get you the correct camshaft for your application. I think I'm going to take your advice and go with the MP528 solid cam. Will it be a direct swap for the Howard's cam/lifters I have now or will I have to change the pushrods as well? I had installed new Trend pushrods when I installed the Comp Magnum rocker arm assemblies.
[Re: 6PAX]
#3092551
11/08/22 12:47 PM
11/08/22 12:47 PM
Posts: 4,206 New York
polyspheric
New York
If the converter is too tight (low stall): ragged idle in gear fights the brakes stronger shock to the axle on shifting > loss of traction
Boffin Emeritus
