Page 3 of 3 1 2 3
Re: impressive run F.A.S.T. Duster [Re: JCFcuda] #3088752
10/24/22 08:27 AM
10/24/22 08:27 AM
an8sec70cuda Offline
It's incredible what these cars run given the rules they are limited by!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: impressive run F.A.S.T. Duster [Re: an8sec70cuda] #3088757
10/24/22 08:38 AM
10/24/22 08:38 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Absolutely
It's also pretty eye opening when you hear what goes into building a really competitive one
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: impressive run F.A.S.T. Duster [Re: Brad_Haak] #3088788
10/24/22 10:51 AM
10/24/22 10:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Absolutely
X3 iagree Those car are impressive for sure.
Re: impressive run F.A.S.T. Duster [Re: racerx] #3089277
10/26/22 08:22 AM
10/26/22 08:22 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice car F1Scamp! GOOD WORK!
Re: impressive run F.A.S.T. Duster [Re: DaveRS23] #3089490
10/26/22 07:43 PM
10/26/22 07:43 PM
CT
roadrunner2 Offline
roadrunner2  Offline
CT
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’
Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST.
10:1 451” replaced with 14:1 499”.
Re: impressive run F.A.S.T. Duster [Re: 83hurstguy] #3089618
10/27/22 11:48 AM
10/27/22 11:48 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Originally Posted by 83hurstguy
Traction control is technically illegal per the rules, but the advantage of using an ECU to pre-program a timing curve is a huge advantage to getting the cars to leave on these tires.
You pretty much have to shave bias plies to true them up at a minimum. The repro tires do hook a lot better as they get down to the tread bars or less... you can run them bald.
The Duster hauls... impressive car.
Traction control is not illegal, that being said I don’t know anyone that currently runs it. Programmable boxes for timing ramps? Yes. Data logging? Absolutely! Active wheel slip feed back to pull timing? I don’t think so currently. I know it was tried in the past, but wasn’t as useful as you would think. At least back then. The real dream CRUSHER is the Duster doesn’t even data log. Let alone have a programmable box. At MIR he would walk by 3-4 of us bragging about our low 1.6’s and complain “damn another 1.51 60’! Why won’t it 60’?!” or “mph was only 128!” What can you expect, I think he gets a hair cut before each race. Weight is weight! 🤣🤣
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Page 3 of 3 1 2 3
