My MIR race results, long story short
#3088556
10/23/22 01:57 PM
10/23/22 01:57 PM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Couldn't get my dial-ins close and chased my tail on reaction times the whole day Ran Mod ET (1/8th) and Street ET (1/4) Won first rounds in both... broke the first-round loss curse I seem to have had - won Mod round chasing a guy down who had a 4-second head start in an 1/8th mile race - won Street ET cuz it was my only really good light all day and the other guy was waayyy off his Lost second rounds in both... to the same guy in both classes - sucked on tree - car slowed down more than expected, especially running Street ET back-to-back w/ Mod ET Would like to have gone more rounds, but... Long day, but a fun one, regardless. Met some new folks, caught up w/ some I haven't seen in a long time
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: My MIR race results, long story short
[Re: Brad_Haak]
#3088558
10/23/22 02:04 PM
10/23/22 02:04 PM
Brad_Haak
Loudoun County, VA
First round Street ET; cut an .027 light running a Hellcat Charger who wasn't able to chase me down on the big end
[Re: Brad_Haak]
#3088560
10/23/22 02:15 PM
10/23/22 02:15 PM
Posts: 14,512 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The FAST guys were running great.
Any new bests for you?
[Re: fast68plymouth]
#3088570
10/23/22 03:05 PM
10/23/22 03:05 PM
Brad_Haak
Loudoun County, VA
Yeah, the F.A.S.T. guys were hauling a$$! So were the KOS guys, but since they don't show the times now, I can only guess... No obvious PBs for my 1320, but maybe some data worthy of I'll have to dig up the slips and see what catches my attention. One thing I can say for sure is this car heat-soaks really badly, even on cool days like yesterday. I've started putting ice bags on the intake between rounds and sitting in staging, but the IAT climbs incredibly fast as soon as I have to start it up while waiting to make a pass. And the heat kills the car by about a tenth and 1 MPH from what I can tell.
#3088592
10/23/22 04:53 PM
10/23/22 04:53 PM
Brad_Haak
Loudoun County, VA
Things aren't always as clear as I'd like them to be, but here's what I found reviewing all my 1320 data... Based only on time slips with complete results for 1/8th & 1/4 ET & MPH (I do have some better results that come from runs where certain data points are missing due to timing system issues), yesterday, the car ran its best 1/8th mile pass: 1.682 60, 7.527 at 92.47 For comparison, the best 60 to date had a complete 1/4 mile run of: 1.680 60, 7.560 at 90.90 (1/8), 11.894 at 113.75 (1/4) And another 11.89x full 1/4 pass with a slower 60-ft, but better MPH: 1.746 60, 7.594 at 91.94 (1/8), 11.893 at 114.38 (1/4) The best 1/4 mile pass to date doesn't have 1/8th mile data, unfortunately: 1.714 60, ——— at ——— (1/8), 11.833 at 115.80 (1/4) I suppose it's possible that a full 1/4 run on that particular 1/8th mile pass would have been a new PB for 1/4 ET, even if not 1/4 MPH. "Maybe next time..." Oh, re being time to get the other car running... that's what Mike Hynes are going to be focusing on this week.
#3088593
10/23/22 04:58 PM
10/23/22 04:58 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Brad , you sound like a mate of mine here . He runs a Holden ute , 6.2LS / 6 speed auto 4000lbs range . Car runs 11.90/12.20s . Same issues runs good then has a erratic big drop off or poor sixty . my opinion is its simply the wrong type of car . His has a tune small cam and a bit more gear . Look to Stock type cars . They will run tune in open (?) loop so it will not adjust when running kind of makes it follow weather like a carb car . Fly by wire is not great for best throttle control and hates whacking throttle in top end .Computer controlled trans may well be the same . Then add a"slow" car which is way more sensitive to DA wind and track and you have an awkward car to race . He is on to his 3rd set of different radials but I dont reckon he has a tyre issue . From Hoosier to MT ETSS to MT PBR now . In 17's or 18's . Just my Oh and heat soak dont even go there . Yes IAT is killer as it pulls timing Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3088598
10/23/22 05:20 PM
10/23/22 05:20 PM
Brad_Haak
Loudoun County, VA
Yep, yep and yep (and another yep, if I lost count).
Here's the solution, Part A
[Re: Brad_Haak]
#3088600
10/23/22 05:22 PM
10/23/22 05:22 PM
Brad_Haak
Loudoun County, VA
[Re: Cab_Burge]
#3088608
10/23/22 05:39 PM
10/23/22 05:39 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I like part A and part B.
[Re: pittsburghracer]
#3088674
10/23/22 11:16 PM
10/23/22 11:16 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
I had an 04 GTO. It had the IAT sensor right by the radiator. It would slow the car down a ton. I moved the sensor when I put a cold air intake on and it helped s bunch.
[Re: slantzilla]
#3088746
10/24/22 06:57 AM
10/24/22 06:57 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I had an 04 GTO. It had the IAT sensor right by the radiator. It would slow the car down a ton. I moved the sensor when I put a cold air intake on and it helped s bunch. I raced my lifted jeep Cherokee with a stroked 4.0 in a few years ago when my car was broke. I ran a pass, helped tow a broken racer back to his pit, and then ran another pass without shutting it off. The engine temp gauge never moved but with the hot intake air it dropped over a second of ET. I am assuming the hot IAT pulled timing and added fuel. Horrible vehicle to try and bracket race, rollout from a 35" tire isn't easy and it was wildly inconsistent.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#3088755
10/24/22 08:34 AM
10/24/22 08:34 AM
Brad_Haak
Loudoun County, VA
Any time you win a round and have fun is a good day Indeed!
[Re: Brad_Haak]
#3088758
10/24/22 08:40 AM
10/24/22 08:40 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Glad you had fun, sounds like a good weekend to me! I wish I could have made it up there. Maybe next year!
[Re: FurryStump]
#3089793
10/28/22 05:35 AM
10/28/22 05:35 AM
Brad_Haak
Loudoun County, VA
Only the 1/8th mile pass I mentioned was from Saturday. All the other 1/4 mile passes I referenced were from other days & tracks.
